comments - revised helmnet standard
Discussion in 'Australian Motorcycles' started by Zebee Johnstone, Dec 28, 2005.
  1. From the MCC of NSW
    Australian Helmet Standard AS 1698
    The Public Comment Period for the review of the Australian Helmet Standard
    is open. Please pass to your technical minded and retrieve comments.
    Comments are to be returned to Motorcycle Council of NSW BEFORE 15 January 2006.
    MCC of NSW is the "Sponsoring Body" for a representative to the Australian
    Standards Committee for Motorcycle Helmets and Protective Eyewear.
    I have not attached a copy of the current Draft, as to make sense of
    that, will require a copy of the original and then require a fair bit
    of work to identify the changes and discover what they mean. Anyone who
    wants to do that, please contact me.
    What I have provided is a brief list of the changes and further down,
    the reasons for them.
    The Committee has made a number of significant changes in this latest
    edition,. which is now open for public comment.
    The principal changes include the following:
    (a) Removal of the requirement for a shell with a hard outer surface
    (Clause 5.1).
    (b) Modification of the requirements for internal projections (Clause
    5.3).
    (c) Addition of a requirement for ventilation (Clause 5.7).
    (d) Increase in the minimum number of helmets to be supplied for testing
    from four to six (Clause 6.1).
    (e) Addition to the test requirements providing a test sequence
    (Clause 7.1).
    (f) Addition of a dynamic test for helmet stability (Clause 7.3).
    (g) Replacement of the static test for the strength of retention systems
    with a dynamic test (Clause 7.6).
    (h) Specification of minimum letter sizes for marking and instructions
    for use and care (Clauses 8 and 9).
    (i) Revision of the marking requirements regarding a helmet which
    experiences a severe blow (Clause 8(f)(v)).
    (j) Addition to the marking requirements that visors attached to the
    helmet meet the requirements of AS 1609 (Clause 8(f)(vi)).
    (k) Addition to the instructions for use and care requirements.
    (l) That visors attached to the helmet meet the requirements of AS 1609.
    (m) That the suitability of communications devices be specified (Clause
    9(e)).
    (n) Revision and amplification of the warning requirements with regard
    to painting and solvents (Clause 9).
    (o) Lowering of the test line following from the revision of AS 2512.1.
    What follows is a short introduction and a brief explanation of each
    change and why it is deemend necessary.
    In essence, the Australian Helmet Standard, AS 1698, has become frozen in
    time (last update 1988), largely as a result of legal action flowing from
    the testing failure of product from a local manufacturer and subsequent
    actions arising. Not all of this was good. However, it is now time to
    move on.
    The administrative framework surrounding AS 1698 means that in Australia,
    we can be assured of "consumer protection", in that the helmet we buy
    is extremely unlikely to be defective. This is due to the efforts to
    "batch test" helmets arriving for sale in Australia. This is one of
    the fundamental strengths of AS 1698 that sets it aside from other
    international regulations or standards.
    Debate continues on the requirement for the penetration test. This
    is a deeply problematical area, with insufficient data. The core of
    the debate is one of testing for and the degree of "shell integrity"
    versus lighter weight. For example, both AS 1698 and the EU Regulation
    are different compromises on achieving a relative combined protection
    from both shell and impact lining. Research projects are currently under
    way. This will be the subject of future work by the Helmets Committee.
    The current course of action is to update what we have, the current AS
    1698 Standard.
    It has fallen behind in time and many tests require use of out dated
    other Standards (e.g. (o) below )
    A little detail on the meaning of each change:-
    (Clause 5.1).
    This was seen as "proscriptive", defining the "look" of a helmet and it
    is felt that this is a design limitation that has only cosmetic value,
    hence it is to be deleted, allowing a helmet to be made with a soft
    outer skin, as long as it still passes the strength and integrity tests.
    5.3).
    This changes a requirement that any projection from the shell be
    limited to less than 5 mm internally or externally. (WAS 2mm for all
    but chin strap mounts). Also, that the projection is part of a mounting
    for a limited range of specific items (eye protection, ventilation,
    communications, retention systems (e.g. strap mounts), life support
    equipment)
    This is a requirement for adequate ventilation to nose and mouth,
    particularly for strapless full face helmets that close around the neck
    or chin.
    This is about statistical reliability, increase sample size increases
    reliability of tests.
    (Clause 7.1).
    Commonsense dictated that the tests should be performed in an order
    that made sense, this simply states that. (e.g. test helmet stability
    on headform before doing strength tests on the strap system - the strap
    placement may be perfect, but after being tugged to the limit, it may
    not perform well in stability).
    This is an important addition. Many helmets rotate forward off the
    head of the wearer in a crash. It is a fundamental test that was
    missing from the old Standard. You can also use a simple version
    of this test to tell if your helmet fits you properly too (see
    http://www.roadsafety.mccofnsw.org.au/a/74.html )
    An important change, to reflect the real world situation of the strap
    getting a sudden jerk, rather than a steadily increasing pull.
    A straightforward label requirement. Some riders need to wear glasses
    or use magnifying glasses to read some labels. At least now, you'll know
    it's not the print size.
    A rewrite to this: "(v) If helmet experiences a severe blow, destroy
    it and replace it."
    "A new phrase: (vi) Ensure that any visor attached to this helmet meets
    the requirements of
    AS 1609."
    This is "guidance" to the owner of the helmet. The clear visor that came
    with your full face will have an AS1609 (Eye protectors for Motorcyclists
    and Racing Car Drivers) Mark, as it is a legal requirement at point
    of sale. Now check out the Iridium vapour or tinted dark visor and look
    for markings.
    It was seen to be a little silly to embed this as an absolute requirement
    in use, as you can wear dark sun glasses (of ANY shade, shape or
    composition behind a clear visor, but not a tinted visor without sunnies.
    In essence, it is guidance on the strength of a visor. With no marking
    on the visor, there is no guarantee that it meets the minimum strength
    requirement. However, when your dark visor is made by the same company
    as made the approved clear one, you'd wonder if they felt it was OK to
    reduce the quality of the materials being fed to the moulding mnachine,
    but we still don't know officially whether the additives for colour have
    a negative effect upon the strength or not.
    Some on-going issues with the AS 1609 Standard may see a review of the
    tinting requirements. You may be aware that glass tinting is also a
    difficult area.
    A fair bit of information to be put in a brochure or label to accompany
    a new helmet. As noted below:-
    (a) No helmet can protect the wearer against all possible impacts.
    (b) For maximum protection the helmet must fit firmly on the head,
    and the retention system must be securely fastened. With the
    retention system comfortably but firmlyadjusted, it should not be
    possible for the helmet to be removed from the head when pulled
    at the rear in an upward and forward
    direction.
    (c) Ensure that any visor attached to the helmet shall meet the
    (d) The helmet is suitable/unsuitable* for use with goggles.
    (e) The helmet is suitable/unsuitable* for use with communications
    devices. (If suitable for use with communications devices, list
    the appropriate devices.)
    (f) No attachments should be made to the helmet except those
    recommended by the helmet manufacturer. Do not drill or cut
    the shell.
    (g) The helmet is designed to absorb shock by partial destruction
    of the shell and liner. This damage may not be visible. Therefore
    if subjected to a severe blow, the helmet should be replaced even
    if it is apparently undamaged.
    (h) The liner is essential to the intended performance of the
    helmet.
    (i) The helmet has a limited lifespan in use and should be replaced
    when it shows obvious signs of wear, e.g. change of fit, cracks,
    rust or fraying."
    A simple change that clarifies this point. The visor in fact forms part
    of the overall helmet for the purposes of the Standard and hence this
    is made clear that the required Standard is AS1609.
    9(e)).
    This is the one that may cause concern, as these devices are entering
    the market rapidly and retro-approval is unlikely.
    I would prefer to see this as a "class" of device or some form of broad
    definition. This may be limiting in the market if the helmet maker does
    not do this.
    A necessary addition to the label. Many are ignorant of the effects of
    painting upon structural integrity.
    Solvents in paints can cause chemical degradation of polycarbonate helmets
    (moulded helmets) and de-lamination of tri-layer types. Some glues used
    on stickers can also have this effect.
    This is a "catch-up" item. Essentially, the old Imperial headforms
    (from the British Standard) have been superseded by different sized ISO
    headforms suitable for different size helmets and this leads to a number
    of numerical differences in the test methodology and also some shape
    differences, with one result being that the "test line" for measuring
    peripheral vision from a helmet has altered.
    - end -
