Cold starting (or not) tips please...
Discussion in 'UK Motorcycles' started by Doesnotcompute, Nov 27, 2003.
  1. It would appear that with the change to somewhat colder weather (I'm
    getting frost now) the VS is objecting to being run in the mornings.
    I'm guessing this is cold related as opposed to my recent electrical
    tinkering related because it's trying to turn over. Hell it is turning
    over. Just not catching very well. after a few mins of turning it will
    then catch better and better until vroom, all is well. I'm presuming
    this is something warming up? plugs? fuel in carbs? furcked if I know.
    I'm a bit concerned about what happens the day it doesn't catch, or I
    kill the battery, whichever is sooner.
    So, any tips? [1]
    [1] "get a real bike" or similar is not acceptable as a "tip" :)
  2. Doesnotcompute
    deadmail Guest
    a) Take the plugs out and warm them with a blowtorch first.
    b) Use some easy-start to get it to catch...
    or...
    c) check all connections related to ignition. It could well be that
    you've got a weak spark, removing any resistance in the connections due
    to corrosion will improve this. Replacing the plugs won't hurt.
    Remember, when it's cold the battery doesn't have as much oooommpphhh as
    it has when warm.
    Ah!
    d) light a small fire under the bike before trying to start it.
    deadmail, Nov 27, 2003
  3. Doesnotcompute
    Steve Parry Guest
    Blowtorch the carbs ... that'll do it ;o)
    Steve Parry
    http://www.gwynfryn.co.uk
    http://wrexhamseals.tripod.com
    Steve Parry, Nov 27, 2003
  4. Doesnotcompute
    paul Guest
    Angle grinder on the petrol tank. That'll warm it up.
    Paul
    paul, Nov 27, 2003
  5. Doesnotcompute
    I used to put them under the grill
    Champ, Nov 27, 2003
  6. This is a pain in the arse on the VS, as the plugs are sunk nice and
    deep inside the engine, so a long/thin handled plug spanner is needed
    and a magnet on a tick for when the plug gets dropped inside the slot on
    the way out.
    Chances are they'd prolly be cold again by them time they're screwed in
    and HT'd up.
  7. Doesnotcompute
    AOL
    ....but in the OP's instance I'd try new ones first. Pretty cheap and may
    solve the problem.
    sweller, Nov 27, 2003
  8. checking the iron in your blood?
    Darren Robinson, Nov 27, 2003
  9. Doesnotcompute
    Verdigris Guest
    On Thu, 27 Nov 2003 09:59:08 +0000, deadmai wrote:
    New HT leads as well.
    Verdigris, Nov 27, 2003
  10. Doesnotcompute
    serf Guest
    A no brainer. Keep it in the living-room.
    serf, Nov 27, 2003
  11. Doesnotcompute
    Platypus Guest
    Heh.
    Platypus - Faster Than Champ
    VN800 Drifter, R80RT, Z200
    DIAABTCOD#2 GPOTHUF#19
    BOTAFOS#6 BOTAFOT#89 FTB#11
    BOB#1 SBS#35 ANORAK#18 TWA#15
    Platypus, Nov 27, 2003
