cold hands
Discussion in 'Australian Motorcycles' started by DM, Jul 28, 2011.
  1. DM
    DM Guest
    Jeeze my hands got cold on the trip to Toowoomba last night. Even
    inside my Dririder Reflex gloves. Longjohns under my jeans worked
    well, as did the fleecy shirt under my Dririder Nordic jacket.
    Any tips for warmer hands?
    DM, Jul 28, 2011
  2. In aus.motorcycles on Thu, 28 Jul 2011 07:54:23 +0000 (UTC)
    The cheap method is dirt bike hand shields.
    (The really cheap method is a 2l milk bottle split down one side
    with a bit cut out, use a hose clamp to clamp the lid end round the
    bars and a self tapper to fasten the base end to the end of the
    grip)
    Blocking the wind makes a huge difference.
    The more expensive method is heated grips. You can get them
    aftermarket on ebay.
    Zebee
    Zebee Johnstone, Jul 28, 2011
  3. DM
    atec77 Guest
    If you can't find some decent wind blocks a couple of plastic bags over
    the gloves and news paper inside the jacket
    atec77, Jul 28, 2011
  4. DM
    Peter Guest
    Heated grips rock!
    Peter, Jul 28, 2011
  5. DM
    Yeebok Guest
    Not when they're installed correctly..
    Yeebok, Jul 28, 2011
  6. DM
    G-S Guest
    Andy Strapz sell thermal inner gloves, combine those with V-Strom style
    handlebar wind deflectors and heated grips and your hands should be warm
    even if the rest of you is still freezing :)
    G-S
    G-S, Jul 29, 2011
  7. DM
    GWD Guest
    Can definitely recommend heated grips... and heated seats.
    GWD, Jul 29, 2011
  8. DM
    TimC Guest
    Am I the only person who finds heated grips almost useless?
    They heat the inside of your hands up, but you still can't feel
    anything and it hurts to pull the brakes in because the outsides are
    frozen solid.
    Almost as useless as a bonfire in the centre of a circle instead of
    the bonfire being a ring around you to heat all sides simultaneously
    (although they must work a little bit. One side wasn't working due to
    dust in the connector, when I went through Lithgow at 1degC. That
    hand spent more time on the cylinder head)
    TimC
    You see, wire telegraph is a kind of a very, very long cat. You pull
    his tail in New York and his head is meowing in Los Angeles. Do you
    understand this? And radio operates exactly the same way: you send
    signals here, they receive them there. The only difference is that
    there is no cat. -- Albert Einstein on radios.
    TimC, Jul 29, 2011
  9. DM
    Nev.. Guest
    I think you may be.
    It sounds like you're doing it wrong. (Or maybe you don't have any
    other kind of wind protection on your hands). Get better gloves.
    Nev..
    Nev.., Jul 29, 2011
  10. DM
    Addinall Guest
    Don't go out.
    I lost a glove going over Mt. Snowdon in 1975.
    That was fucking fun.
    Right glove as well. So I put the left glove
    on upside down, and made it down the mountain with
    my left hand stuck mostly in my jacket.
    Tried not to change gears to often. It got a bit
    scary handling the ice with one hand on the bars!
    Had a pint and 17 whiskies when I got down.
    A bit of Alice Cooper, a small joint, and a ****
    with a local chubby chick sorted it out.
    Mark Addinall.
    Addinall, Jul 29, 2011
  11. DM
    Diogenes Guest
    No. I wasn't impressed by them when I had the R80.
    Zactly.
    But I do think in conjunction with wind deflectors they work fine.
    Onya bike
    Gerry
    Diogenes, Jul 29, 2011
  12. DM
    Buzz^| Guest
    Easiest way to keep warm is stay away from Toowoomba. I quite happily
    ride about without gloves and have never had chilly hands. I do prefer
    gloves when riding rivers due to grip. Was quite chilly last Sat night
    in Madang, I needed a sheet to keep the breze off while sleeping.
    Brad Leyden
    6° 43.5816' S 146° 59.3097' E WGS84
    To mail spam is really hot but please
    reply to thread so all may benefit
    (or laugh at my mistakes)
    Buzz^|, Jul 29, 2011
  13. DM
    Nigel Allen Guest
    My last pair of serious winter gloves (admittedly ex-UK) had a
    "mitt-like" think that stowed in a zip on the back of the wrist. When it
    got really cold you could unzip them and pull them over the back of your
    hands. Difficult to explain without pictures.
    Here's a similar one. http://tinyurl.com/3k5j8c2.
    N/
    Nigel Allen, Jul 30, 2011
  14. DM
    TimC Guest
    The R1200GS has both. I am considering getting even bigger envelopes
    for the barkbusters. My thick winter gloves certainly work (to the
    extent that they become uncomfortable very quickly when the
    temperature starts to rise), and in the Alps on days when it got down
    to 1degC, the addition of overgloves seemed to be the first thing I
    found to actually work. I sometimes wore them even when I wasn't
    expecting rain because, even though they were bulky and you lose some
    feeling of the controls, they kept my fingers from distracting me with
    their pain.
    But Betty, it's regularly -6degC on your commute? You've got balls of
    harder steel than mine.
    TimC, Jul 30, 2011
  15. DM
    GWD Guest
    Yes, and/or good gloves.
    Having been in a few sub-zero situations over extended periods, I can
    vouch for them, but I have to admit the RT is well set up for wind
    protection. As someone has already suggested, Barkbusters plus heated
    grips seem to fit the requirements for protection plus heat. I'm not
    experienced enough to make recommendations, only to report what works
    for me.
    GWD, Jul 30, 2011
  16. DM
    Nev.. Guest
    On an unrelated note, I see that the brand of those gloves is the same
    as a jacket I bought over in the USA last year. Tourmaster. It's the
    best thought out bit of motorcycle apparel that I have owned.
    Everything seems to be in the right place and easy to get at even with
    gloves on. It has very effective ventilation and all the vents can be
    completely closed and the jacket does a great job of keeping the cold out.
    Nev..
    Nev.., Jul 30, 2011
  17. DM
    atec77 Guest
    The fibre sure has
    the limiting factor though is the interconnecting hardware assuming
    the right fibre is choosen
    atec77, Jul 30, 2011
  18. DM
    Moike Guest
    Well done! That was almost recognisable as english.
    Moike
    Moike, Jul 31, 2011
  19. DM
    atec77 Guest
    My comments are specifically directed at netizens who think they’re
    correct because they’re English is perceived to be better in contrived
    instance . Whether not one makes a series of typos or can speak
    English doesn’t effect your argument content or linearity of thought .
    It occasionally might hinder ones ability to express yourself properly
    to a slow that normal English user but that’s about it and lame
    attempts to use this as a lever for gain is rude and irrelevant rather
    like fingering ones ears whilst making lalala sounds compounding ones
    own ignorance and possibly removing an important experience . So many
    people get into arguments with those who don’t have English as their
    first language, and they make retorts about how the other person is
    “stupid†and “needs a better English teacher.†That’s just so irrelevant
    in the larger scheme and a poor excuse historically considered as a fail .
    Secondly, such obsequiousness in an attempt to fit in with the
    playground ethic smacks of desperation. Because you cannot reasonably
    argue your point without having to make random jabs at the other
    person’s background then you only embarrass yourself. Do you really
    think the fact English is your only language makes you a better person
    somehow and ignoring the actuality of being short on experience in the
    field of discussion somehow hides the fail on your part ?Your slavish
    adherence to monosybilic English and constant pointing out of that fact
    is a fail in the larger scheme which makes you the ‘stupider’ one in
    this situation. Rail against you own retardation and peek out from under
    the warm covers whilst butt sniffing and look around
    Now explain in clear concise terms what my reply meant in actuall
    trade term with url as required
    atec77, Jul 31, 2011
  20. DM
    Jeff R. Guest
    TL;DR
    Jeff R., Jul 31, 2011
