Coincidence or Stuff Up
Discussion in 'Australian Motorcycles' started by will_s, Aug 11, 2007.
  1. will_s
    will_s Guest
    New rear tyre on the BMW K1200R yesterday and rode it straight home (
    looking back I think it sounded funny when it started ). Today ready to
    scrub the tyre in and the bike really sounded funny when started so turned
    it off and then it wouldnt turn back on. Dead as a doornail or whatever .
    Anyway being too lazy to walk back into my flat and get the riders manual I
    took a cover on the petrol tank off and there was the battery ( thought
    fuses might have being there ) and the right terminal was very loose so
    tightened that up and no problems ( well for a little while ). Bike started
    and went ok .
    Now would they disconnect the battery terminal when changing a tyre ?
    Anyway after a 100k quick trip went to the local shops and when about half
    way home noticed the general warning light on and a strange symbol appeared
    in the multifunction display which turned out to be the engine electronics
    symbol and it means it has diagnosed a fault which one would assume would
    have being caused by the battery terminal coming loose.
    Anyway the afternoon ride is now cancelled and come Monday its the bike back
    to the bikeshop.
    Will_S ( $318 worse off and unable to ride the fucker )
  2. will_s
    SmeeMW Guest
    I find it odd they would disconnect the battery to change a tyre.
    they'd have to almost remove the petrol tank just to get to my battery.
    I've seen them replace the reat of my tyre takes all of 20 minutes to
    remove and replace.
    undo the brake caliper, 4 wheel nuts, remove wheel, remove tyre, put
    on new tyre, balance, put wheel back on tighten up the 4 bolts then bolt
    on the brak caliper again.
    Nope can't see where the battery removal would come into it.
    SmeeMW, Aug 11, 2007
  3. will_s
    Boxer Guest
    Sounds like the computer has been fried and it is running on default limp
    home mode, should only cost $3-4,000 for a new computer :)
    Boxer
    Boxer, Aug 11, 2007
  4. The more likely scenario is that the terminal vibrated loose over time.
    Shaun
    Shaun Van Poecke, Aug 11, 2007
  5. will_s
    will_s Guest
    thankfully its under warranty
  6. will_s
    will_s Guest
    Cant see it myself but no problems up to then....maybe just a coincidence
    but in over 30 years ok bikes and cars have never seen a terminal come loose
    by itself
    also took over a hour to do and think they unbolted the exhaust system from
    the rear
  7. will_s
    Boxer Guest
    That is good news.
    Boxer
    Boxer, Aug 11, 2007
  8. will_s
    will_s Guest
    why not ?
    Its not something you would expect to check daily especially as it is under
    a cover that you need to remove 3 screws that have a different head then
    normal. I would assume that it wasnt put on correctly in the 1st place .
    Like I have said elsewhere I have never seen a terminal cable come loose in
    30 years.
  9. If the bike is fitted with an alarm and/or immobiliser that would be the
    easiest way of isolating it. So they might do that as a matter of
    course, whether an alarm is really fitted or not.
    I've had something similar appear in the Volvo a couple of times.
    Turning the ignition off, waiting, then turning it back on again got rid
    of it. Is this fault light of yours persistent?
    Andrew McKenna, Aug 11, 2007
  10. will_s
    will_s Guest
    has an alarm but they had the keys
    well took it out a hour later and it came on so its leave it alone until
    Monday.
  11. will_s
    SmeeMW Guest
    Best you do that because if you disconnect the battery and get rid of
    the memory all fault codes will reset themselves.
    Although if you do ride it the faults may become more apparent.
    Have you checked the wires that connect to your oxygen sensor are on
    properly since you said they removed the exhaust?
    Also check any other wires that connect to sensors near the shaft.
    Whatever you do don't disconnect the battery or the fault codes will be
    purged.
  12. will_s
    Nev.. Guest
    If you google for the fault codes and how to retrieve them you might be
    able to find exactly what it's trying to tell you. Might be something
    completely unrelated. What does the owner's manual say about the light?
    Nev..
    '04 CBR1100XX
    Nev.., Aug 11, 2007
  13. will_s
    steve Guest
    Had a similar experience when my 3mth old 'bird stopped dead in it's tracks.
    Loose battery terminal wasn't allowing enough charge through to keep battery
    from going flat. Lucky no damage done to electrics in this case tho.
    (bloody hard to push any distance...)
    S.
    steve, Aug 11, 2007
  14. will_s
    will_s Guest
    Wont even be going near the bloody thing. Had a quick look at the oxygen
    sensor on the exhaust and it appeared ok but who knows.........
    I notice in the manual it says after connecting the battery to fully open
    the throttle once or twice and the engine management system registers the
    throttle valve postion
    In a bit over 2 weeks its off to the Gold Coast bike week with a group of
    mostly Harley's so I just hope its a minor hiccup
  15. will_s
    will_s Guest
    electronics symbol and it means it has diagnosed a fault and you can
    continue to ride but the usual engine power might not be there and to have
    the fault rectified ASAP
    since the loose terminal had the same result as disconnecting the battery it
    says short circuit can happen if connected in the wrong sequence and I
    notice in the manual it says after connecting the battery to fully open the
    btw: I did about 100k's before the fault happened
  16. will_s
    bikerbetty Guest
    shit yes.... how embarrassing if a Beemer crapped itself while a bunch of
    Harleys kept going..... how would you ever live THAT down!
    betty <evil grin>
    bikerbetty, Aug 11, 2007
  17. will_s
    Nev.. Guest
    so why cancel the ride ?
    Nev..
    '04 CBR1100XX
    Nev.., Aug 11, 2007
  18. will_s
    will_s Guest
    oh you evil bitch :)
    what makes it worse is that I rubbish the shit out of them, every ride I
    enquire who is driving the breakdown vehicle
  19. will_s
    will_s Guest
    you can continue to ride but bear in mind that the usual engine power might
    not be available
    look I am not sure on what damage may happen or may not happen
  20. will_s
    Nev.. Guest
    If they system is smart enough to know that there is a problem, and it
    will continue to operate, but may drop power, then surely if would shut
    down the system entirely if it detected a problem which may cause damage.
    Nev..
    '04 CBR1100XX
    Nev.., Aug 11, 2007
