Coating conundrum and rusty disc
Discussion in 'Classic Motorbikes' started by Pete Fisher, Feb 11, 2008.
  1. Pete Fisher
    Pete Fisher Guest
    Having acquired a 77ish Morini 350 for the Forgotten Era hill climb
    project I have been merrily stripping it down to the essentials today. I
    may do a TOG and Ebay the surplus bits out or might keep them in case I
    ever want to put it on the road. The angle grinder is not coming in to
    play this time, unlike when I built my original Morini hill climber in
    1980. Everything removed is being safely stored in a box.
    Anyway, the cast wheels, front brake caliper, and side cover badges
    seemed to painted in garish gold. The frame and tank has been painted in
    red to a standard reasonable enough for the track and I assumed someone
    had thought it would look good with gold accessories.
    I discovered though that the 'paint' is soluble by petrol. In fact it is
    all a bit tacky (to touch not just look at). Lo and behold under the
    gold is the same dull silver finish that my 79 Sport had as original.
    The 250 has faded gold wheels BTW which was standard.
    So could it be some kind of demon anti-rust compound that someone has
    applied liberally (it has been in storage for years), or has someone
    just slapped a totally inappropriate type of paint on? It is almost like
    a thin coating of copper grease IYSWIM.
    Which ever it is, what is likely to be the best solvent to remove it
    quickly?
    Unfortunately they didn't coat the cast iron front disk with it. What
    appeared on cursory examination to be surface rust has actually pitted
    the surface slightly. A bit of a pain as the disc is otherwise not
    scored and seems to have been professionally drilled. I think I have a
    stainless one on in the shed and I can even borrow the 250 one if all
    else fails, but is it worth having it skimmed, or will the slightly
    mottled surface left once the rust goes be OK.
    | Pete Fisher at Home: |
  2. Pete Fisher
    AW Guest
    I spoke to Alex at NLM recently about skimming Morini disks and the
    answer was a comprehensive No. It should be OK as is if not scored
    and if it's only surface that'll soon come off!
    AW, Feb 11, 2008
  3. Pete Fisher
    Pete Fisher Guest
    In communiqué
    If it was only surface rust of the kind I used to get on the Guzzi I
    would just get on with it, but a bit of close examination shows loads of
    tiny pits in the surface. Never seen a disc do badly affected. Could
    make for improved wet weather braking I suppose, or a stick in the wheel
    effect which might be interesting to say the least.
  4. Pete Fisher
    AW Guest
    Ebay item 120217788132? - a completed item, but it's on a BIN and
    they had a few of them.
    Pricey, but I wish it had come up before I bought a new standard disk.
    AW, Feb 11, 2008
  5. Pete Fisher
    Pete Fisher Guest
    In communiqué
    <checks price>
    I think I'll pass. Particularly as it also shows all the usual symptoms
    of a weak spark. Having one old and one new type transducer is another
    issue. From experience with the K2 I know they will work (indeed it does
    run on two) with an old type red pickup, but the advance will not be
    correct on one pot. I have enough components to make one good system,
    but it's time to prod about with the multi-meter tomorrow. The coil in
    the stator is probably on its last legs.
  6. Pete Fisher
    I'd bang it in and see what effect it has in actual use (a couple of runs
    up and down the road will show if it'll come good).
    sweller, Feb 12, 2008
  7. Slightly? You want to see what condition the discs on your car are in if
    you leave it sitting for a year or two. Slightly is nuffin' to worry
    about, what counts is how it works. Don't be replacing them until a
    crack shows, which is pretty rare on CI discs.
    Grimly Curmudgeon, Feb 13, 2008
  8. It'll clean up fine in use. worth checking that it's still within tolerance
    for thickness, though, CI discs work much better and wear faster.
    Austin Shackles, Feb 14, 2008
  9. Pete Fisher
    Pete Fisher Guest
    In communiqué <>, Austin
    Well, with the master cylinder and caliper borrowed from the 2C [1] it
    seems OK at garden path speeds. Whether it will induce sufficient
    retardation after the finish at Hartland in April is another matter. I
    think I may be able to put it in to the 2C to bed it in before then
    though, along with the nice new pads I have treated it to.
    [1] Caliper is identical but master cylinder smaller bore. This is
    generally reckoned to give a better brake, and born out by my own
    experience.
    Pete Fisher, Feb 18, 2008
