CO2 fire extinguisher.
Discussion in 'Motorbike Technical Discussion' started by ian field, Jan 30, 2009.
  1. ian field
    ian field Guest
    An application that requires compressed gas - a CO2 fire extinguisher is
    known to be a suitable source.
    Does anyone know how I can obtain a couple of fire extinguishers that have
    been taken out of service (but are more or less full)?
    Obviously scrap prices would be preferable.
    TIA.
  2. ian field
    ian field Guest
    Its for fitting tubeless tyres - but its definitely a "don't try this at
    home" unless you know what you're doing!
    ian field, Jan 31, 2009
  3. ian field
    zoot Guest
    you can get a tank at ?-mart for 20 bucks
    zoot, Feb 2, 2009
  4. ian field
    ian field Guest
    Tank of what? - Here in the UK, one trader showed me a compressed air
    canister for seating tubeless, he said getting it charged is only about £4
    but the initial outlay is over £80 - not a lot I know, but a bit steep for
    only once or twice/year use the scrap fire extinguisher is a better deal.
    ian field, Feb 2, 2009
  5. ian field
    ian field Guest
    Not if you turn it upside down - it really is that simple.
  6. ian field
    zoot Guest
    o k tire pump 20 bucks no 10 bucks.
    sheeeeeeesh!!!!
    zoot, Feb 2, 2009
  7. ian field
    ian field Guest
    sheeeeeeesh!!!!
    That can seat a tubeless tyre?............tell me more.
  8. ian field
    ian field Guest
  9. ian field
    . Guest
    Yes, you *can* seat the beads of many tubeless tires with an ordinary
    car tire pump.
    But you have to get the beads out of the drop center of the rim and
    into the area where they will normally seat.
    Automotive tire changing shops have an inflatable cloth section of air
    hose that wraps around a car tire and hooks to itself. When inflated,
    it squeezes the tire bead against the rim so it can be more easily
    inflated.
    I didn't have one of those gizmos, but I did have a come-along (coffin
    hoist).
    I wrapped the cable spirally around the tire which I had previously
    placed on the rim.
    Then I hooked the end of the cable back to itself near the ratchet
    frame and cranked the cable tight with the ratchet handle.
    The cable provided enough mechanical pressure on the beads to make a
    seal
    and I used my tire pump to seat the beads.
    I learned to do this trick when the local gas stations started
    installing those silly
    low volume compressors that I need to put coins in to get air for my
    car tires.
    ., Feb 2, 2009
  10. ian field
    Mark Guest
    It is quite possible to seat tubeless motorbike tyres with only a mini
    12volt tyre inflator.
    For Trailer tyres I carry a 2.5Kg color gas bottle on the breakdown van,
    pressurise this to 80psi and then dump it quick into the tyre.
    Mark, Feb 2, 2009
  11. ian field
    ian field Guest
    Operating the extinguisher upside down avoids filling the tyre with liquid
    CO2, a quick jab on the lever works perfectly - using a bottle with a rotary
    valve would be much more dangerous. It goes without saying that this is done
    with no valve core fitted in case there's a need to let the pressure out in
    a hurry.
    ian field, Feb 3, 2009
  12. ian field
    ian field Guest
    I've bought 2 different 12V pumps - one turned out to be an expensive
    ornament, the other is roll a cigarette and sit down and have a smoke while
    it rattles away making a lot of noise and not doing much very fast.
    A few years ago I saw a documentary on an Arctic expedition, they were using
    4WD trucks with large balloon tyres which turned out to be prone to knocking
    off the rims, they demonstrated a trick of squirting lighter butane into the
    tyre and lighting it so the explosion blew the tyre back onto the rims,
    although its pretty unlikely there are enough square inches on the inside of
    a motorcycle tyre for this to work.
  13. That was in a Top Gear episode where J & J in a car were racing
    R in a sled to the "North Pole" (actually the geomagnetic[1] pole, quite some
    distance from the geographic pole), with a group of Icelanders(IIRC) as the
    backup crew for the car. The Icelanders showed Jeremy the trick.
    [1] Somehow that word was never said, but the sat-nav display showing
    78-degrees when they were looking for the "exact" spot rather gave it away.
    Dr Ivan D. Reid, Feb 3, 2009
  14. Pancake style pumps sometimes get crud between the
    rubber "pancake" flap and the surface that it's intended
    to seal
    to.
    Deep down in the plastic housing is a little single
    cylinder pump with the rubber flap under the cylinder
    head.
    The cylinder head can be removed and replaced to
    clean the pancake. The pump then starts working better.
    I saw something about this too. You might still find a
    use for that fire extinguisher.
    Rob Kleinschmidt, Feb 3, 2009
  15. ian field
    Dieseldes Guest
    I think the original was TG in Iceland aabout 5 years ago, up mountains
    with a group of mad Icelandics (they all are)
    I have tried that trick with a 145 13 tyre that had been stored for a while
    and there was no way it was going yo seat on the rim! The resulting bang ,
    mechanics exiting the workshop, I had no hair on the back of my arm and the
    tyre was perfectly seated on the rim!! Next time a bit less lighter gas....
    So a bike tyre no problem.
    I would have used the same method again last weekend putting winter tyres on
    Saab rims but someone hid the gas :(
    Des
    Dieseldes, Feb 3, 2009
  16. ian field
    Dieseldes Guest
    We do the same, ex 19Kg gas cylinders filled to compressor pressure 120psi,
    they have been invaluable on breakdowns and have reseated bike and car
    tyres at the roadside, enough to get them back to the garage.
    Des
  17. ian field
    paul c Guest
    My little obsession is how much I can do with minimal tools. The biggest tire I have set the bead for was something like 130mm wide on 13 or 14 inch rim (scooter), using a $60 compressor that had a 1.5-gallon tank. Might have taken three or four short blasts to set but if I had wrapped a tie-down around it first, I'll bet it could have been done with exactly two blasts of about two or three seconds each (I've never seen anybody set both beads with one blast). Now what I wonder is whether a similar-sized tank sans compressor, the kind some husbands I know put in the trunk so that their wives won't 'phone them when they get a flat, would suffice. I presume one could get 70-90 pounds into those with about five minutes of pumping using one of those cheap foot pumps. Those little tanks usually already have the valve hose and attachment and a pressure gauge. I guess they're made in China, but I often see them on sale for about twenty bucks.
    If I may drift the topic a bit, I quite agree that a small compressor is almost essential at home if one likes to do one's own maintenance and repairs, not for air tools per se, but for cleaning carbs, drying parts, removing brake pistons and a few other things I forget. However, it seems to me that a group of people going on a trip or even a short rally might find it makes sense for one of the riders carry a small tank and foot pump with them. Much less weight than even a small compressor. What do the people here think about this, eg., what is the biggest tire a 1.5 gallon tank could set the beads on? (Of course, there is always foam for getting home, I always carry it and the stuff I've used is remarkable, have given it twice to people who got home without problem. Note I'm not talking about the "Slime" et al that some people insert in anticipation of a flat.)
    paul c, Feb 4, 2009
  18. ian field
    zoot Guest
    like i said 20 bucks. if you don't have a pump, your closest mechanic
    does. go see him 2 times a year if that's all you need. hell bring it
    over to my house and i'll fill it
    zoot, Feb 4, 2009
  19. ian field
    ian field Guest
    to seal
    to.
    head.
    ian field, Feb 4, 2009
  20. ian field
    ian field Guest
    Somewhere I have a Camping Gaz cylinder which I don't use anymore, the
    clever bit would be making my own fittings to pump it up and then coupling
    it to a tyre valve.
