CM450 carb problems
Discussion in 'Motorbike Technical Discussion' started by novascroller, Jun 28, 2007.
  1. novascroller
    novascroller Guest
    its an 1984 honda cm450e. it has VB22 carbs (CV) I'm having
    hesitation/stuttering at about 1/4 to 1/2 throttle. the carbs have
    been professionally cleaned and synced. the slides move easily
    in the bore. once past this "stuttering" it runs fine. i just had
    the carbs apart again to doublecheck and couldn't find any dirt in the
    jets. these aren't the original carbs for the bike but every jet
    has been properly sized as per the service manual. what am i
    missing?? thanks.
  2. novascroller
    Ed Cregger Guest
    Weak spark.
    Ed Cregger
    Ed Cregger, Jun 28, 2007
  3. novascroller
    novascroller Guest
    spark fat and blue, new plugs, coils measure fine.
  4. novascroller
    novascroller Guest
    1. Incorrect idle mixture screw adjustment. If the idle mixture screw is
    checked the plugs, the tips are light gray in color and the insulator
    is a very light brown. .
  5. novascroller
    John Guest
    The plugs will clean up ok if it's only fouling occasionally. You'd need to
    drive the bike for a while at the throttle opening that's causing the
    problem and them stop and check plugs.
    John.
    John, Jun 28, 2007
