Clutch vs. neutral
Discussion in 'Motorbike Technical Discussion' started by 1970 Suzuki TS250, Jul 26, 2004.
  1. When you press a well adjusted clutch with the engine OFF, is it just
    as easy to push the bike than it is on neutral (engine off)?
    On this 1970 TS250, it seems that there is some resistance to push the
    bike forwards or backwards when depressing clutch lever (engine off) -
    not like having the engine in gear and not pressing the clutch, but a
    lot more resistance than in neutral.
    Is this normal, or is the clutch in need of adjustment? In other
    words, is the bike on the clutch supposed to behave exactly as in
    neutral when the engine is off?
    Thanks!
  2. 1970 Suzuki TS250
    Josh Assing Guest
    it's normal. Try it when before you start the bike; then start the bike and
    try it (clutch in) -- it'll be easier with a warmed up bike... but you'll still
    feel resistances vs. neutral.
    Josh Assing, Jul 26, 2004
  3. 1970 Suzuki TS250
    Matt Whiting Guest
    This is normal with a multi-plate wet clutch. When the oil is cold and
    thick, it will drag a fair bit as the plates aren't all that far apart
    even when the clutch is disengaged.
    Matt
    Matt Whiting, Jul 26, 2004
  4. Thanks for the replies - much appreciated.
    I also found this interesting link:
    http://www.clarity.net/~adam/buying-bike.html
    I quote:
    "**=Wet clutches may tend to stick or drag a bit until the bike has
    warmed up and the clutch has spun a bit. This is often the case when
    the clutch hasn't been used in a while. Wait until the bike has really
    warmed up before you dismiss a potential acquisition for having an
    overly-sticky clutch. "
    On another topic...
    I am looking for some links on noises from the engine and the clutch -
    troubleshooting. I am not sure what kinds of noises are normal on
    this kind of bike, and which ones might be the cause of some concern.
    For now there is a noise from the clutch in neutral which goes away
    when I depress the lever (slight vibration sounding noise - perhaps it
    needs to be readjusted) and there is friction sounding noises at
    certain rpms, probably from the cylinder.
    So if anyone can suggests good links on motorcycle noises
    troubleshooting, post them here.
    TS250
    1970 Suzuki TS250, Jul 27, 2004
