I have a 1982 Honda CB 125s. I have been restoring it. Have not had the bike started yet. I have spark, compression, carbs working. Clutch doesn't seem to be doing anything. In first gear, there is hardly any difference between the clutch engaged and disenaged. Transmission works fine, but clutch doesn't seem to be clutching. When I try to push start the bike, the piston doesn't move with clutch enganged or disengaged. The piston does move if I try to kick-start it, but I can't start the bike that way. A friend told me I would probably have to push start it to get it started the first time. Any suggestions on the clutch problem? Or any suggestions on getting the engine running? Thanks Hammer
