Clutch problem on 94 Shadow 1100
Discussion in 'Motorbike Technical Discussion' started by JohnH, Jun 4, 2006.
  1. JohnH
    JohnH Guest
    The clutch on a 94 Shadow 1100 I amworking on is giving me fits. I've
    just bled the clutch (over and over) and got all the air bubbles out.
    I "spurted" the top banjo bolt to make sure there's not an air bubble
    up there too. When the bike's not running, I can drop it in first and
    roll it with the clutch in and feel just the slightest resistance, so
    the clutch is obviously disengaged. However, with the bike running,
    dropping it into first (or second) with the clutch in kills the motor
    immediately.
    What gives?
    John H.
    JohnH, Jun 4, 2006
  2. JohnH
    FB Guest
    Sidestand up or down?
    Could the problem be a sidestand safety interlock switch shutting off
    power to the ignition coils?
    There is an inscrutable logic of neutral switch, clutch switch and
    sidestand switch on modern motorcycles to make a fool of the rider who
    thinks he
    understands them.
    Honda and Yamaha rely on the sidestand safety interlock switch to OPEN
    when the sidestand is down, as I recall, but Kawasaki is opposite, they
    rely on the sidestand safety switch to be CLOSED.
    My Suzukis just make a sidestand light go ON when the stand is down.
    FB, Jun 4, 2006
  3. JohnH
    JohnH Guest
    Grr. Now I remember why I ride a Harley. Don't get me wrong, the
    Honda is a nice ride, but just like their cars, they are always telling
    me what I can and can not do. You are of course right, and thanks for
    the advice. It got me because I never imagined I couldn't even put the
    bike in gear with the sidestand down.
    Next thing, is there an adjustment for the range? The clutch works ok
    now, but the action is within the last half-inch of the level pull,
    making it a bit jumpy. On a normal mechanical clutch, I could adjust
    this but I'm a bit lost with this hydraulic thingy.
    Thanks again!
    John H.
    JohnH, Jun 4, 2006
  4. JohnH
    FB Guest
    I remember the first time I encountered the ignition safety interlock
    on an American car. If your passenger got pissed off and grabbed the
    ignition key and threw it out the window, the steering wheel would lock
    in the straight forward position. What kind of genius thinks of stuff
    like that?
    The DOT and the motorcycle manufacturers have worked to somewhat
    standardize
    the control systems on motorcycles in order to protect novice riders
    from harming themselves in certain situations.
    This standardization sometimes makes experienced riders into idiots. I
    remember telling the lot boy at the Suzuki dealers that I had been
    riding forever, and there was nothing he could tell me about
    motorcycles. Then I switched off the engine and couldn't restart it.
    Suzuki had introduced the clutch safety interlock switch to keep the
    motorcycle from lurching forward if the starter button was pressed
    without disengaging the clutch. The
    safety interlock didn't have anything to do with the sidestand or the
    neutral switch.
    My Yamaha FZR1000 has a circuit that links clutch, neutral switch, and
    sidestand into a logic that shuts of the ignition if I put the
    transmission into gear with the sidestand down. The starter won't crank
    the engine if it's in gear or if the clutch isn't disengaged. Too
    complicated.
    Each Japanese manufacturer has their own ideas about how to build a
    motorcycle and they respect each others' intellectual property. So it's
    amazing that they can get anywhere near a standard for protecting
    riders from their own klutzy mistakes. I have been in situations where
    I believe the safety interlock system caused me to crash.
    I looked at the clutch master cylinder fiche for 1994 VT1100C Shadow on
    www.partsfish.com. You can register on that site and look at diagrams
    for free. or you can use www.bikebandit.com
    If there is any adjustment for where the clutch engages or disengages,
    it might be that
    # 2 push rod that is between the barrel on the clutch lever and the
    internal guts of the
    master cylinder. The # 2 rod may be threaded.
    There doesn't seem to be any clutch adjustment access hole in the right
    side crankcase cover. It looks like the clutch slave cylinder is on the
    right hand side of the engine. A "clutch piston" is shown the clutch
    diagram.
    FB, Jun 4, 2006
  5. Someone who's telling you that you should be more selective in your
    choice of travelling companions....
    The Older Gentleman, Jun 4, 2006
  6. JohnH
    John Johnson Guest
    Isn't it now the case that vehicles with the steering wheel interlock
    also typically prevent you from removing the key unless it's in the
    "off" position? There might very well have been a time when this wasn't
    true, but I've not run into an automobile made in the last 20 years that
    didn't have both features.
    Later,
    John
    John Johnson, Jun 5, 2006
