I have a 1983 Honda Shadow VT750. I recently rebuilt the engine and finally put it back into the frame. When I tried to start it, it just clicks and kills. The clutch pedal became stuck in gear, and I think that is causing it to kill, obviously. However, I bled the clutch, but it does't build up any pressure to be able to disengage the clutch. When I was rebuilding the engine, I accidentally pulled the clutch lever, and read afterward that is bad. It said something about the piston in the slave cylinder. Could that be the problem? If so, how do I fix it? Any other suggestions on how I can get it out of gear and just try to start it? Any advice is welcomed. Please help! I'm so close to getting this bike running, and I think this may be the holdup. Thank you!
