Clutch oddness.
Discussion in 'UK Motorcycles' started by gazzafield, Feb 16, 2007.
  1. gazzafield
    gazzafield Guest
    Bike has been laid up over winter - wuss that I am - apart from a very
    occasional run to work. Has had three or four runs in the past three weeks
    as the weather improves slightly. I noticed on Wednesday that the clutch
    was rather heavy when pulling on the lever.
    This morning it was the same except the clutch lever returned so slowly the
    clutch was slipping unless I pushed the lever back myself. This happened
    for about a half a mile when I stopped to think about going back and getting
    the car. But in good biker tradition I thought, "**** it" and carried on.
    A couple of miles down the road everything was fine.
    The bike has now been sitting for a couple of hours and I had a squeeze of
    the lever. It's heavy again. Is this a sticky cable or shagged clutch
    springs? What does the panel think?
  2. gazzafield
    Sticky cable. Whip it off at both ends (not necessarily off the bike
    altogether) and squirt some WD40 down inside the outer cable. Work
    the inner back and forth and it'll get easier: when it does, let the
    WD run out and dribble some 3-in-1 down it until it comes out the
    lower end. Reassembly, tec.
    Pip, Feb 16, 2007
  3. gazzafield
    gazzafield Guest
    Swot I had assumed seeing as it gets easier as it starts moving. I shall
    squirt lots down the cable tomorrow. It's a right pain in the arse when
    first setting off.
  4. gazzafield
    Pete Fisher Guest
    What you need is a natty pressure cable oiler of the type I acquired
    many years ago. Put on cable outer with inner inside oiler. Fill with
    appropriate lubricant and put on screw on top with bicycle pump adapter
    thread, then pump a few times with bike pump and leave a while. Reaches
    parts other methods cannot reach. Don't know if you can get them
    anymore.
    If Pip's cable lube scenario is not a complete answer consider any
    clutch push rods or little pivot jobbies there may be. Many bikes have a
    thingy that transfers the pull on the cable in to a push on an actuating
    rod. This sometimes has very poor bearing arrangements (if any) and poor
    access for lubrication. The one on the WR250 was a case in point.
    | Pete Fisher at Home: |
    Pete Fisher, Feb 16, 2007
  5. I get one of those little plastic bags they use for coins in banks.
    Make a small hole in the bottom. Poke the end of the cable through it.
    Seal round the hole with tape or suchlike. Squirt some fine oil or WD40
    into the bag, and let it run down inside the cable. Leave for a couple
    of hours.
    Refit cable.
    The Older Gentleman, Feb 16, 2007
  6. gazzafield
    Molly Guest
    This is what happened with my GSX.
    Molly, Feb 16, 2007
  7. gazzafield
    mcbrib Guest
    Snip
    Thats what happened on a GXSR400 I was working on just before the
    cable snapped.
    Ben
    mcbrib, Feb 16, 2007
  8. gazzafield
    ts Guest
    When lubing cables[1], I've ended up using a 10 or 20 ml syringe, with
    an as long needle as I can get (40-50 mm). After filling the syringe
    with oil (gear oil, asuming a heavier oil does not drain as quickly from
    the cable) I attach it to the needle, which I've inserted as long into
    the upper end of the cable I can get it. Gentle pressure on the syringe
    piston, and the oil ends up where it should be, i.e. inside the cable.
    [1] not teflon lined cables, which may cause them to stick.
    ts, Feb 16, 2007
  9. gazzafield
    I've got one of those PJ11 spray-can type clamp-on oilers. They're
    about forty percent effective: forty percent goes in the cable, sixty
    percent pisses out round the outside.
    Pip Luscher, Feb 16, 2007
  10. gazzafield
    Pip Luscher says...
    I've got one of those, it works about as well as yours
    Lozzo, Feb 16, 2007
