Clutch kits
Discussion in 'UK Motorcycles' started by Eddie, Nov 1, 2004.
  1. Eddie
    hahahhaha!
    darsy, Nov 1, 2004
  2. Eddie
    oh - I thought you might be complaining about the stiffness. Surely the
    "problem"[1] with the biting point is adjustable?
    [1] I can't remember what it was like
    darsy, Nov 1, 2004
  3. Eddie
    What? And you call yourself a UST!
    Champ, Nov 1, 2004
  4. Eddie
    Christofire Guest
    It probably is. However, the biting point being in the wrong place is
    my excuse for fluffing up just about every first pull-away I do on
    someone else's bike.
    After a few gear changes I'm usually on it, but that B12 takes longer
    which I attribute to either the heaviness prevents me using it gently
    or I'm a PFF.
    Christofire, Nov 1, 2004
  5. Eddie
    Eddie Guest
    I've got it on video. :p
    Eddie, Nov 1, 2004
  6. Eddie
    Of course you have. I mean, who hasn't?
    Champ, Nov 1, 2004
  7. Eddie
    Champ wrote:
    [tommy]
    I don't.
    In fact, I've not even sat and watched it all the way through.
    darsy, Nov 1, 2004
  8. Eddie
    Well, of course *you* wouldn't. But, given that I'm a fan of a) The
    Who, and b) Ken Russell, it's one of my favourites.
    Champ, Nov 1, 2004
  9. Eddie
    I don't mind The Who, and I like some Ken Russell movies ("The Devils"
    is, predictably, a favourite). I just have never gotten around to
    watching "Tommy" the whole way through in one sitting - I'm pretty
    sure I've seen every scene, IYSWIM.
    It couldn't be any near as good as "24 Hour Party People" in any case.
    darsy, Nov 1, 2004
  10. Eddie
    AndrewR Guest
    Nothing comes close to "Lair of the white worm" I'm afraid. It's a class
    act which has been unfairly maligned by some film snobs with no appreciation
    of the finer things in life.
    AndrewR, D.Bot (Celeritas)
    Kawasaki ZX-6R J1
    BotToS#5,SBS#25,IbW#34, TEAR#3 (and KotL), DS#5, COSOC#9, KotTFSTR#
    The speccy Geordie twat.
    AndrewR, Nov 1, 2004
  11. Eddie
    AndrewR says...
    It's only good cos some burds get their tits out. Apart from that it's
    crap.
    Lozzo, Nov 1, 2004
  12. Eddie
    Right, bonny lad. I made a bit of a study of the Bandit12 when I was
    fortunate enough to have one. They have clutch 'issues', see.
    First off, a race can *will* liberate ~10bhp. My Scorpion made a big
    difference to mine all through the range and sounded a sight better
    than the standard sewing machine impersonator too.
    Freeing up that 10% will have an effect on the clutch, which, if not
    brandly new, slip a little on full chat as it gets a go on in second
    and third (first as well if you're really brave).
    If you use fully synth oil it will slip a lot. Everywhere.
    The best way to obviate the slippage is to use a 'heavy duty' clutch.
    Apparently the plates are a bit 'better'. I dunno what that means,
    tbh.
    The functional point is the diaphragm springs - they squeeze the
    plates together a bit harder - and take more pressure to release.
    The tried and tested way to uprate the clutch is to change *one*
    spring for a Barlow spring. Barlow springs are the 'heavy duty' type,
    and they are sold *only in pairs*. Fit two Barlow springs and you
    need the grip of a blacksmith to squeeze the lever - or at least, to
    repeatedly squeeze it, if you are negotiating town traffic, for
    example.
    Conventional wisdom dictates buying a pair (for ~20 quid) and fitting
    one and flogging the other to a Bandit-owning pal. Leave one of the
    existing springs in place, see.
    IIWY and assuming the clutch is fucked (standard B12 clutches are a
    bit marginal and wear swiftly in the urban environment) then I'd get a
    cheap set of plates and a pair of Barlow springs from a Suzuki dealer
    (they'll know what you want) or one of the Bandit specialists. Fit
    the plates and one of the springs - then try it. Fit both if you feel
    strong, but wax the gasket before refitting so it will come off for
    swappage in a couple of days.
    And I'd stick a cheap race can on it, and make sure the wires are
    disconnected - then get used to leaning forward sharply on every
    overtake. I swear I overtook more cars on A roads on one wheel than
    two, as the fucker picked up off catseyes, ripples in the road and
    white lines everywhere. Fucking brilliant, it was.
    Pip, Nov 1, 2004
  13. Eddie
    AndrewR Guest
    Not true at all; first off hardly any burds get their tits out (an when
    Amanda what-do-ya-mac-call-her does she's painted blue).
    It's got a plot which whips along fast enough, it has a couple of scary(ish)
    moments and it doesn't have a silly happy ending tacked on to it. All in
    all it really doesn't deserver the awful reputation that it enjoys and it is
    Mr Russell at his unrestrained best.
    Kawasaki ZX-6R J1
  14. Eddie
    That'll be Barnet springs, not Barlow, you half-pissed, shagged out
    ugly ginger ****.
    Pip, Nov 1, 2004
  15. Eddie
    DR Guest
    Brings to mind some sort of extra-heavy-duty hair clip...
    DR, Nov 1, 2004
  16. Eddie
    Champ says...
    They have a diaphragm type clutch spring as standard, much the same as
    the R1. A common mod is to double up on the springs using one
    aftermarket heavy duty one and a knackered standard one. Apparently if
    two heavy duty ones are fitted it makes the clutch action worse than a
    Jotas.
    Lozzo, Nov 1, 2004
  17. Eddie
    Salad Dodger Guest
    <ponders impending clutch change on Wing>
    <reaches for handgun>
    | ___ Salad Dodger
    |_\_____/_| ..73063../..16589.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
    Salad Dodger, Nov 1, 2004
  18. Eddie
    Champ says...
    You can convert R1 clutches to take a multi-spring arrangement, but they
    cost a fortune.
    Lozzo, Nov 1, 2004
  19. Eddie
    Ginge Guest
    No, that would be Barnsley..
    Ginge, Nov 2, 2004
  20. Never looked inside a ShiteOldBoxer?
    <Thinks>
    No, I don't suppose you would have.....
    The Older Gentleman, Nov 2, 2004
