Clutch Cover Gasket - liquid gasket ok?
Discussion in 'UK Motorcycles' started by bpwhitehouse, Mar 3, 2008.
  1. bpwhitehouse
    bpwhitehouse Guest
    Anyone ever used liquid gasket on the clutch cover? Thinking of using
    it instead of finding/buying the part.
  2. bpwhitehouse
    You want a silicone gasket material which cures for that, like Loctite 598
    Hog, Mar 3, 2008
  3. bpwhitehouse
    DR Guest
    Don't. Proper gaskets exist for a reason. The liquid stuff
    (Hylomar?) just ends up clogging the oilways, and your engine
    self-destructs.
    DR, Mar 3, 2008
  4. bpwhitehouse
    bpwhitehouse Guest
    Thanks again, just bought some :D
  5. bpwhitehouse
    This man speaks the truth.
    You can get away with using liquid gaskets for years if you're really
    careful about wiping away any excess but the one time you slip up
    could **** your engine if the worst case scenario occurs.
    Andy Bonwick, Mar 3, 2008
  6. Use sparingly.
    And you're a daft twat for not spending a few quid on the proper gasket.
    The Older Gentleman, Mar 3, 2008
  7. bpwhitehouse
    Pete Fisher Guest
    I wouldn't hesitate to use a decent gloop the clutch cover of a two
    stroke, in fact I used some stuff from the local quincaillerie on the
    faux WR250 when I fettled the clutch.
    Not sure I would risk it on the Tart or Nordies.
    <pats dry clutch Morini>
    | Pete Fisher at Home: |
    Pete Fisher, Mar 3, 2008
  8. Nor me. I assumed the OP had a four-stroke, though.
  9. bpwhitehouse
    Mark Olson Guest
    And if you choose your gasket source wisely, you get a free box of
    cornflakes.
    Mark Olson, Mar 3, 2008
  10. bpwhitehouse
    bpwhitehouse Guest
    yes its a 750 katana. now ordered the correct gasket to be on the
    safe side - just wanted to do the job tonight - lazy!
    thanks folks
  11. bpwhitehouse
    Daft sod. It'll leak.
    Champ
    ZX10R | GPz750turbo | GSX-R 600 racer
    My advice as your attorney is to buy a motorcycle
    To email me, neal at my domain should work.
    Champ, Mar 3, 2008
  12. bpwhitehouse
    Pete Fisher Guest
    In communiqué <1id8sfw.c93vfq1ld8fc8N%>,
    A reasonable, and almost certainly correct, assumption these days.
    BTW, after years of generally foreswearing machines from the land of the
    rising sun I am really impressed with both the YZs. The 96 250 goes
    amazingly well and after a decade still submits to disassembly without
    heartache. The lad's 2004 YZ85 is really nicely put together, and so far
    seemingly bomb proof, even after dropping it at the MX practice track
    yesterday and digging the twist grip deep in to the dirt. I hadn't
    instructed him in the need to instantly go for the kill button in such
    circumstances. Screamed it's head off for a few seconds but seems to
    have survived.
    If the four strokes are as good I could be tempted by something with a
    yzf thumper motor.
  13. bpwhitehouse
    SD Guest
    I've used blue hylomar three times on the Wing, and it's never leaked
    a drop.
    SD, Mar 3, 2008
  14. bpwhitehouse
    It's OE on some BMW engine joins and I've never had a problem. Sparing use
    being important.
    Hog, Mar 3, 2008
  15. bpwhitehouse
    Yebbut, I bet you had the old gasket on there as well?
    For some reason I read the OP as using liquid gasket *instead of* the
    paper gasket.
    Champ
    Champ, Mar 3, 2008
  16. bpwhitehouse
    Ah that's a different matter....
    If it requires a gasket then use one but lots of engines have joint faces
    which only use black bond or the like.
    Hog, Mar 3, 2008
  17. bpwhitehouse
    I had an R100/7 that, when I took the sump pan off for a look-see, appeared
    to have been gasketed with fishtank silicon goop. There were strings of
    beads of the stuff floating about in the sump. I cleaned it out as best I
    could, and kept my fingers crossed. A couple of thousand miles later, one
    big end turned its plain bearings into something resembling compressed
    heat-treated tinfoil.
    platypus, Mar 3, 2008
  18. bpwhitehouse
    SD Guest
    Ssshhhh, you'll scare the fishes away.
    I wasn't sure, so went for the deceptively helpful approach.
    SD, Mar 3, 2008
  19. So did I.
