This should make sense :) My clutch cable appears to have stretched or something and now when I change into neutral while stationary it's really hard to move the lever - cut the motor and it slides easy. Also gear changes whilst in motion feel tighter. A couple of weeks back I had it adjusted at the handlebar end which completely resolved the problem - at the time I was told any more adjustment would need to be done at the other end of the cable. Anyway it's happening again. I've had a look and I agree, there's no adjustment left there. Having a look there, there's this kind of assembly : Spline (or whatever they're called) that goes into the engine box Shackle attached to the cable. Far as I can see there's no adjustment there. Then there's a long threaded sleeve (a hollow bolt the cable's fed through) with a metal bracket and 2 nuts either side of it. From there the cable heads up to the handlebars. It appears moving these in some fashion should do what I want. Do I need to make them further apart, closer together, further up the cable or down it ? It's not something I want to frig with unless I've asked some advice first. Yes this is Fritz, the Hyosung Gt250 in case it's relevant but I figure to most extents they're all similar.
