Clearing out an idle circuit the lazy way
Discussion in 'Motorbike Technical Discussion' started by Mike W., Mar 27, 2008.
  1. Mike W.
    Mike W. Guest
    Hello,
    I have a couple of 99 KZ1000P cop bikes that until this winter I was
    scrupulous about maintaining. In one of them, I left no gas that had not
    been fuel stabilized. It started right up last night but wont idle.
    question... Can I fix this chemically? There is NOTHIGN I hate more than
    taking the carbs off these things. Will carb cleaner screw up things like
    my float valve seals? Is there some fuel treatment that'll get it done
    while I sit there and hold it open?
    Your assistance will be greatly appreciated.
    Mike
    Mike W.
    96 XR400
    99 KZ1000P
    70 CT70
    71 KG 100 (Hodaka-powered)
  2. Mike W.
    Wudsracer Guest
    Mike,
    Before dismantling the carbs, add a bunch (at least three times the
    recommended amount) of Chemtool B-12 (the B-12 with the acetone, I
    believe) in the tank of fresh fuel and ride it a bunch. This ought to
    help with your problem. At least it is cheap, and won't hurt.
    Then, if needed, you can always take em off and soak the carb bodies
    in Berryman carb dip. Call me for any specific tips if it goes that
    far. (although you have probably read my methods before, on rmd.)
    Load the KZ up and come down here. I know of a lot of really fun
    back highways to take up several days of fun. On top of that, while
    you are here, I'll furnish you a dirt bike, and take you on some
    delicious single track.
    Bring your cones, and give me some instruction on the KZP. I think
    I'd like that.
    Wudsracer/Jim Cook
    Smackover Racing
    '06 Gas Gas DE300
    '82 Husqvarna XC250
    Team LAGNAF
    Wudsracer, Mar 27, 2008
  3. Mike W.
    . Guest
    You might try adding 4 or 5 ounces of Berryman B12 Choke and
    Carburetor Cleaner to a full tank of gasoline and riding until the
    carbs clean themselves out. GumOut or STP carb cleaners will work too,
    but the reason I like B12 is you can get it in the non-aerosol can and
    measure it precisely without spraying it out of the cup you're going
    to pour into the gas tank.
    B12 contains stuff like MEK and acetone and toluene, so keep it off
    your paint.
    It takes a while for carb cleaners to attack plastic and rubber parts
    and I have found that rubber parts soften and swell up, but return to
    their original sizes as the carb cleaner evaporates.
    More severe port and jet clogging requires at least some disassembly.
    As I recall, there were two type of idle mixture screws used on
    KZ1000's with slide type carbs, and one type has the idle mixture
    screw coming in from the side, while the other has the idle screw
    coming up from below.
    If you screw the idle mixture screw all the way in before removing it,
    you can write down the number of turns so you can get back to the
    original settings after removing the screws and spraying carb cleaner
    into the hole to clean out the idle
    port.
    Also, find the pilot air screw and squirt carb cleaner through that
    jet to clean out the idle mixture circuit.
    ., Mar 27, 2008
  4. Mike W.
    Mike W. Guest
    JIM! Damn nice to hear from you! I got it cleared... poured some techron in
    the tank and ran it for 15-20 min winding it out every now and then while
    parked. Then I pulled into the street and wound it out hard up to 5th...
    closed the throttle and started doing dirtbike downshifts, shocking the
    idle circuit. Same deal going home... idled perfectly.
    You have no idea how much I'd like that. I hate my job like I can't tell
    you. Tues I was in the damn chair for 19 hours with no breaks. I'll get
    down there some time. It's really high on my list. I saw a reference
    someplace that Smackover (comes from "Sumac cover":) has a newspaper. Say
    high to Maybelle for me a fuss a little. You know how she likes that:)
    I'd be pleased too. But let's see if I stay with this. I have a mental
    log-crossing I have to clear before I start that back up. We'll see.
    Supposed to make instructor level this summer so I won't let it go without
    a fight:)
    Mike
    Mike W.
    96 XR400
    99 KZ1000P
    70 CT70
    Mike W., Mar 28, 2008
  5. Mike W.
    Ron Seiden Guest
    Try dumping a couple of ounces of lacquer thinner into the tank and sloshing
    it around. It's both highly flammable and will dissolve any crud in the
    system. (I've used this method to start up and run bikes that had wintered
    with un-stabilized gasoline in the tanks.)
    Ron Seiden, Mar 28, 2008
  6. Mike W.
    Mike W. Guest
    Great suggestions. Many thanks... saved for the next time the problem is a
    bit more stubborn.
    Mike
    Mike W.
    96 XR400
    99 KZ1000P
    70 CT70
  7. Mike W.
    . Guest
    Berryman B9 carb dip is some nasty brown shit that smells like it came
    out of a Porta-Potty.
    It contains cresylic acid, and it would be good for cleaning up
    suspension parts off of an old 1972 Torino that had set out
    in the weeds for 30 years after being driven for 250,000 miles.
    But I wouldn't use B9 on any motorcycle part, it's just the wrong
    stuff.
    ., Mar 28, 2008
