Clearing Flooded Cylinders...
Discussion in 'UK Motorcycles' started by Dynamic, Mar 3, 2004.
  1. Dynamic
    Dynamic Guest
    ....preferably without the use of a blowtorch.
    The GSXR (400 GK71F) hasn't started since my uncle had it running the other
    night, and since I'm not putting it on the road until I've sold the goose, I
    figured that now would be a good time to strip the carbs.
    Took them out, cleaned the jets and other bits and pieces. Wrote down what
    jets were where for future reference. Why are 1 and 3 running on 100, while
    2 and 4 are running on 96? I would of presumed that all the jets would be
    the same.
    Anyway, put the cleaned out carbs back on, and the bike still didn't start.
    Took the plugs out which appeared wet, implying that the cylinders were
    flooded(?) probably from trying to start the bike.
    Cleaned of the plugs and reinserted them. Pressed the started, got a couple
    of backfires, then back to nothing again[1]. Took the plugs out, which were
    wet again.
    The bike turns over, but won't make any attempt to catch, so I've left the
    bike with the battery on charge.
    So, is the flooding why the bike won't start, and how do I clear the
    cylinders?
    [1]Also tried with the choke off and throttle fully open, as heard this
    helps get more air in with flooded cylinders?
  2. Dynamic
    Cammo Guest
    Leave the bike and let them drain into sump, or turn it over
    without the plugs in and stand clear.
    Cammo
    VT500 Rat
    GSX750SE Katana
    GT250-X7
    GT380
    http://cammo.webs.bikers-engine.com
    cammo at bikers-engine dot com
    Cammo, Mar 3, 2004
  3. Dynamic
    Sorby Guest
    Have you asked on microsoft.public.excel.misc ?
    Sorby, Mar 3, 2004
  4. Dynamic
    Sean at work Guest
    Usually they are the same. I'd have expected the outer pair to run the 100s
    and the inner pair the 96s or all 100s, not 1+3,2+4 like that.
    You have got the plug leads back on the correct plugs haven't you. If you
    have them crossed up, the plugs will spark, but not at the correct time and
    you will get an occaisional backfire. Usually paired 1+4,2+3
    Remove the plugs, ground the HT leads -well away from the plug holes- turn
    engine on starter for a few seconds.
    Yes and no. Mostly yes. With the plugs in, there will be a pressure drop as
    the piston descends, which will draw fuel. Nowhere near as much as when the
    engine is running, but some fuel will get through.
    Sean at work, Mar 3, 2004
  5. Dynamic
    Dynamic Guest
    So why aren't they :- /
    Yeh, sparks on all 4. I left the plugs out while I went to work, then gave
    the cylinders a blowout with the airline when I got in (with a long stick
    attatchment, so I didn't blow shit in) and it fired up ok after that, so I
    think it was just flooded.
    <This is where my sig would be if I had quotefix>
    Dynamic, Mar 4, 2004
  6. Dynamic
    Dynamic Guest
    I'll ask on one of the GSXR400 forums.
    Yep, they're even numbered for the terminally stupid.
    Left the plugs off while I went to work, then gave the cylinders a blow out
    with the airline when I returned. Seemed to do the trick.
    OE...
  7. It can happen, because of airbox flow characteristics, that air
    distribution to the carb intakes isn't even. I've come across ones where
    the middle two are running ok, but the outer two are a bit on the
    airstarved side and have slightly smaller jets as a consequence.
    Yours seems to be arse about tit, so I wonder if someone has swapped
    over the jets when rebuilding the carbs.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Mar 5, 2004
  8. Dynamic
    Dynamic Guest
    We were thinking along the same lines. There are legit reasons why you could
    need two different jet sizes, but we can't think of any why they would be
    run in that order.
    The guy who set it up is either a genius, or was totally wankered at the
    time.
    Dynamic, Mar 5, 2004
  9. Dynamic
    I thought it was more to do with the inboard cylinders getting less
    cooling, so are setup with a slightly richer mix to keep things nice and
    cool.
    Muck, Mar 5, 2004
  10. Possible; but I wonder if that reason would lead to a benefit or not.
    <shrug>
    Who knows the mysterious way of the designer. Whatever; it seems to
    work, but there is obviously a limit on how different the outer/inner
    cyls can be to each other.
    GS 850 x2 / SE 6a
  11. Dynamic
    My Bandit is fitted with different inner / outer cylinder jets, but the
    dyno jet kit has all the same jets for some reason. Who knows... :)
    Muck, Mar 5, 2004
