Cleaning plugs
Discussion in 'UK Motorcycles' started by Hooligan, May 8, 2005.
  1. Champion grades go up a number in heat ratings - the next one up would
    be an S10 or S11 if they make them.
    The equivalent NGK (whatever number it is) would go down a number for a
    hotter plug.
    Grimly Curmudgeon, May 8, 2005
  2. Blimey. Ta for that. I never knew. I just assumed higher number =
    harder/colder plug and lower number = softer/hotter.
    I thought it was a universal.
    The Older Gentleman, May 8, 2005
  3. Hooligan
    Hooligan Guest
    This is the one.
    John (jsp)
    SV 650
    Black it is
    And Naked
  4. You're right for NGKs, and the vast majority of bikes use 'em anyway.
    Champion have always been the other way round. Or rather, NGK have
    always been the other way round from Champion, iyswim.
    I grew up using Champion, but I found their failure rate to be
    unacceptable compared to NGK.
  5. Hooligan
    Ahh.. A renault, explains the situation.
    You can usually change pistons and rings without taking the engine out..
    in a normal car, a renault would be a little different. :)
    Have you tried Holts piston seal, would that be a solution?
    Muck, May 8, 2005
  6. Hooligan
    Maybe it's running rich on one pot? Is that pot near a cole start
    injector or something that could be leaking? Or is one injector a bit
    fucked? Or is it a carb based system?
    Muck, May 8, 2005
  7. Hooligan
    Hooligan Guest
    and a 130,000 mile on, at that..
    NO, I haven't. It might, might it?
    John (jsp)
    SV 650
    Black it is
    And Naked
  8. Hooligan
    Hooligan Guest
    It's injection.
    Diagnosis is beyond me on this one, but the garage I use, who do seem
    to be quite good, say it's a worn ring allowing a bit of oil to pass
    through. If that doesn't sound quite right, it's becasue it's a while
    since they told be so my memory has gone a bit blurred on the matter.
    John (jsp)
    SV 650
    Black it is
    And Naked
  9. Hooligan wrote :
    A black and oily plug would be consistant with a badly worn or cracked
    oil control ring. Does it make a ticking noise? That would be a cracked
    ring.
    I've never needed to try it, but the Holts Piston seal someone
    mentioned might work for a while.
    Harry Bloomfield, May 8, 2005
  10. Hooligan
    John said it was a carboned up plug, which may mean a fueling problem?
    If it's not a concave top piston.
    Muck, May 8, 2005
  11. Hooligan
    Which cylinder is having the problems? If it's bad enough to knacker a
    plug, I'd expect it to be burning oil so you can see blue smoke when the
    engine is hot. Winging Courier haf a car that used more oil than petrol,
    and that didn't stop through choked up plugs, from what I can gather.
    Muck, May 8, 2005
  12. Hooligan
    Hooligan Guest
    The plugs are black. Not sticky or damp, but hard dry black.
    John (jsp)
    SV 650
    Black it is
    And Naked
  13. Hooligan
    Martin Guest
    A quick google for spark plug cleaners
    http://www.frost.co.uk/item_Detail.asp?productID=9104
    Frost do a lot of odd little home restorer tools.
    Martin:
    VTR1000 Firestorm
    Martin, May 8, 2005
  14. This used to be a fairly common problem on old cars of the 60s/70s. A
    cylinder with a broken ring or slightly worn bore/piston (as has been
    mentioned) can foul the plug through oil useage without much in the blue
    smoke department. It's just using a bit more oil in that cyl than
    normal.
    A hotter plug was the time-honoured method of living with it.
    Probably hottish plugs to start with.
  15. Hooligan
    raden Guest
    I put mine in the shot blaster at work
    raden, May 9, 2005
  16. Hooligan
    raden Guest
    Well it still looks like a steel electrode encased in ceramic to me
    raden, May 9, 2005
  17. Hooligan
    raden says...
    I buy new ones
    Lozzo, May 9, 2005
  18. Hooligan
    raden Guest
    'Coz you don't have a shot blaster ...
    raden, May 9, 2005
  19. Hooligan
    Hooligan Guest
    Hooligan, May 9, 2005
  20. Hooligan
    raden says...
    Cos I'm not pikey enough
    Lozzo, May 9, 2005
