Cleaning plugs
Discussion in 'UK Motorcycles' started by Hooligan, May 8, 2005.
  1. Hooligan
    Hooligan Guest
    A car question, actually, but I'm sure someone in this FOAK knows.
    Assuming you had a problem with your car engine, such that one plug
    gets regularly fouled: say once a month or so. Is there a way of
    cleaning the plug, besides wet'n dry? If not, I'll stick to replacing
    them.
    John (jsp)
    SV 650
    Black it is
    And Naked
  2. Hooligan
    If that were happening to me, I'd have fixed the cause already. Would
    something like soaking it in Oven cleaner work I wonder? Buy another
    plug and keep a spare clean one in the glove box.... sort of thing.
    Muck, May 8, 2005
  3. Whaa-aat?
    Brass wire brush & petrol, mate.
    The Older Gentleman, May 8, 2005
  4. Hooligan
    Hooligan scribbled on the back of a napkin:
    .... I'd simply try to get that fixed.
    Timo Geusch, May 8, 2005
  5. The Older Gentleman explained :
    I've done that, but conventional wisdom suggests that brass deposits
    will be left on the insulator causing it to short. The correct method
    is to use a grit blasting machine for plugs, which every garage used to
    have - though no more.
    Perhaps that one cylinder needs a hotter grade of plug?
    Harry Bloomfield, May 8, 2005
  6. Hooligan
    Harry Bloomfield says...
    Have you ever thought that something may not be right with the one
    cylinder that keeps oiling the plug.
    Just a thought like
    Lozzo, May 8, 2005
  7. Andy Bonwick formulated on Sunday :
    Every garage used to be equiped with a Champion combined grit blaster
    and plug tester, in the days when plugs used to foul up regularly. In
    the top was a rubber sealed hole, through which you pushed the plug
    tip, then compressed air then blew fine grit at the tip leaving the
    plug like new. The tester tested the plug under high pressure/voltage,
    to check for high voltage break down.
    I would suspect that many of the longer established garages will still
    have these relics providing good service.
  8. Hooligan
    Andy Bonwick emerged from their own little world to say
    I remember the Ford dealer in Monmouth having one of those machines. It
    would have been around 1968 when my dad was their tractor salesman.
    Exactly
    wessie, May 8, 2005
  9. Hooligan
    These aren't the "good old days"
    Things have moved on, and so has technology
    Lozzo, May 8, 2005
  10. My local dealer had one for sale in his shop for *ages*. Might still be
    there.
  11. Lozzo brought next idea :
    The question asked was how to clean a plug properly. These machines
    cleaned the plugs properly.
  12. In uk.rec.motorcycles, The Older Gentleman amazed us all with this pearl
    of wisdom:
    Actually, I had one (not a big garage one, obviously) bought from
    Halfords when I was a baby faced 16 year old. I think they sold it on
    the gimmickry of it because, although 12v and it deed indeed blast grit,
    it was utter shite.
    I'm not saying a big garage one that worked off compressed air would be
    less effective but the one I had I used off my TS50X battery ;)
    Hahaha! You live and learn, eh?
    Whinging Courier, May 8, 2005
  13. Go up a grade hotter for that plug. Assuming that all the other causes
    are fixed (bad carburettion, duff ignition, valves, etc) and it's
    burning oil in that cylinder.
    Grimly Curmudgeon, May 8, 2005
  14. Hooligan
    Plug technology has moved on, with new materials being used. These old
    machines may not be suitable for modern plugs
    Lozzo, May 8, 2005
  15. Andy Bonwick pretended :
    Because engines run much cleaner internally. We no longer need to
    decoke them or grind the valves in regularly.
  16. After serious thinking Hooligan wrote :
    Just to add to the other answers, there will be two possible
    problems...
    1. The plug gap being shorted by carbon debris, thus preventing the
    plug firing.
    2. Carbon build up on the insulator nose, which can produce a similar
    effect of shorting the plug.
    1 can be cleared simply by passing something through the gap perhaps
    combined with cleaning/reseting the gap, but the only way to clear 2
    properly is with the use of a grit blaster.
  17. Hooligan
    Hooligan Guest
    The trouble some worn ring in the cyclinder which, I am told, would be
    inordinately expensive to fix ( > £1000) which is not worth it.
    Admittedly, most of the cost is labour, as to get inside an espace
    engine you seem to have to dismantle most of the front end of the car.
    I'm prepared to have a go at most things, but getting inside the engine
    itself would be a step further than I've ever been prepared to go
    before.
    Spare plugs are aplenty, adn I recyle the ones from the good cylinders,
    but if I could clean them up and reuse them, I would elevate myself to
    another echelon of pikeyhood.
    John (jsp)
    SV 650
    Black it is
    And Naked
  18. Hooligan
    Hooligan Guest
    I know something's wrong, but the cost of repair v the value of the car
    doesn't make it worthwhile. I've live with it for a bit, whilst I
    finish paying a loan off, then it's a gonner and I'll buy a new one.
    John (jsp)
    SV 650
    Black it is
    And Naked
  19. Hooligan
    Hooligan Guest
    OK, might try that.
    How do I find out what hotter plug will work? atm I use Champion S9YCC
    John (jsp)
    SV 650
    Black it is
    And Naked
  20. Hooligan
    Hooligan Guest
    One word: cost. Relative cost, at least.
    John (jsp)
    SV 650
    Black it is
    And Naked
