Cleaning fork seals instead of replacing them
Discussion in 'Motorbike Technical Discussion' started by Masospaghetti, Mar 24, 2007.
  1. Hi all--
    Have a 1980 Yamaha DT100 with about 1900 miles on it. The fork seals are
    leaking. A mechanic told me that often, if you raise the fork seal
    (without taking the forks off) and get all of the grit from around the
    seal, it almost always fixes the leak. Here's my question -- has anyone
    tried this, and how would I get the fork seal off a fork that is still
    on the bike? Thanks
    -J
  2. He was actually the lot boy that sweeps up and moves motorcycles
    around. The shop manager promised to teach him to be a motorcycle
    mechanic when he's 18...
    The fork oil seal is what is called a "lip seal". The seal is V-shaped
    in cross section, and the sharp edges of the V are what seals the oil
    into the fork leg.
    If the edges wear off, the seal leaks because the contact pressure is
    reduced due to the increase in area at the points of contact...
    Oil seals have a coil spring inside whose ends are hooked to each
    other making a circle. It's called a "garter" spring because a garter
    was what a woman used to hold up her nylon stockings before the
    invention of pantyhose.
    The spring has a certain amount of tension on it, but whatever tension
    it has is not enough to keep the lips from sealing when they are worn
    flat from being abraded by dust and grit.
    No, I never even heard of that idea. Maybe the "mechanic" was
    successful in wiping off all the oil that wept past the seal because
    of air pressure changes while the bike sat in the garage over the
    winter.
    Summer air is usually higher pressure because of solar heating and air
    gets trapped inside the fork. Winter air is colder and lower pressure
    because of the dampness. Air trapped inside the fork during the summer
    pushes oil past the seal during the winter.
    So the mechanic wipes off the weepage around the
    oil seal and strikes the forks up and down and sees no ummediate
    leakage. He charges the customer for
    his "expertise" and sends him on his way. A few weeks or months later,
    the customer's forks start leaking badly...
    Well, you could remove the fork caps and fill the forks all the way to
    the top with motor oil. Then ride the motorcycle over a jump and land
    on the front wheel. The fork seals will be blown out by oil pressure.
    What a mess.
    You might as well plan on removing the fork legs and
    disassembling the forks and replacing the seals properly.
    Potage St. Germaine, Mar 24, 2007
  3. Er, no, wrong.
    You can't. You *can* (however) replace a fork seal without dismantling
    the forks.
    The Older Gentleman, Mar 24, 2007
  4. This is nonsense.
  5. Masospaghetti
    Wudsracer Guest
    The only way the seals will come out without dismantling the forks, is
    to fill each leg completely with fork oil and, using a tie down or
    press or something to help compress and hold the forks compressed,
    push the seals out hydraulically with the fork oil (after raising up
    the wiper and removing the locking clip/ring from above the seal).
    This is messy, and I would only do it off the bike, with the fork
    leg in a bucket and a rag wrapped around the seal area. If you go to
    that much trouble and don't want to dismantle the forks completely, I
    would go on and wash the forks out with automatic transmission fluid,
    put in new seals, and fill to the proper level with fork oil.
    If I dismantle the forks, I always clean the internals with kerosene,
    and rinse them with contact cleaner before reassembly.
    On the bike, you can try cleaning the seal by:
    1. Raise the fork wiper.
    2. Clean the area above the seal (and below the wiper).
    3. Using a strip of 35mm film negative (some use a cut * shaped piece
    of plastic soda bottle, but whatever you use, it needs to be smooth):
    a. Work the plastic down between the seal and fork tube,
    b. Rock the rear of the plastic down (moving the front of the plastic
    upward),
    c. Slide the plastic out back, up, and most of the way out, dragging
    any grit out of the seal's sealing surface with the top edge of the
    plastic.
    d. Wipe the plastic clean after each stroke.
    4. Repeat this "sawing" motion with the plastic strip, at least all
    the way around the seal. I do this twice around the seal.
    If it is very gritty, with much debris, I will clean the strip and
    repeat the procedure.
    I only use this procedure IF the fork seal is just barely weeping,
    to make sure I need to go through the trouble of completely servicing
    the fork.
    If the fork is losing enough oil to make a puddle while it is in a
    relaxed position (relaxed = bike is not in the truck or trailer with
    the forks compressed with tie-downs), I just replace the seal and be
    done with it..
    A puddle of oil on the floor below a fork leg, at anytime, usually
    means a new seal is in order.
    For travel, I always vent the forks after compressing the tie-downs,
    if possible. Most of my old Yamahas had Schrader valves on the top of
    the fork caps, but not sure if the DT100 did.
    I added KTM fork bleeders to the fork caps on my GasGas.
    Mark gave you excellent advise. He always does.
    Those are indeed, some of the easiest forks you will find to work
    on.... IF, you read the service/shop manual on them first.
    Wudsracer/Jim Cook
    Smackover Racing
    '06 Gas Gas DE300
    '82 Husqvarna XC250
    Team LAGNAF
    Wudsracer, Mar 24, 2007
  6. Wrong.
    There's a tool for it, and I've used it.
  7. Masospaghetti
    billybob Guest
    It is also a very wise idea to change the air in your tires as the winter
    air will give you a false tire pressure because of the moisture. Summer
    air, having more helium in it, allows for better tire pressure thus your
    bike will ride higher on the surface of the road. A friend of mine fills up
    old propane bottlesd with summer are to insure he has enough to last all
    winter.
    billybob, Mar 24, 2007
  8. Masospaghetti
    Gene Cash Guest
    Wow. I have to save this. I think I'll frame it on my wall.
    -gc
    Gene Cash, Mar 24, 2007
  9. Masospaghetti
    billybob Guest
    Thought you'd get a kick outta that!!! ;-)
    billybob, Mar 25, 2007
  10. Motorcycle forks will breathe air in and out past the fork seals with
    barometric pressure changes. All the fork oil should be in the bottom
    of a conventional fork, but the pressure changes will cause the fork
    seals to weep oil even though the fork isn't stroking up and down.
    There are other pressure and humidity effects that a
    sportbike owner should know about.
    I used to push my motorcycle out of the cold garage where it had been
    sitting all week and check the tire pressure and I would always find
    it was about 1 or 2 pounds low, so I would add air.
    I thought I might have a slow leak...
    When I got to the twisty mountain roads about 15 miles away, my tires
    would be up to operating temperature and they would feel a little
    skittery because of 2 PSI too much air in the tires...
    Dry air expands proportionately to the temperature rise. I figured it
    rises about 1 PSI for every 10 degrees F inside a motorcycle tire.
    It's not too difficult to deal with rising tire temperatures below the
    boiling point of water.
    Moisture in compressed air will heat up and expand to 1300 times its
    original volume when your tread temperature gets above 212 degrees F
    on the race track. That makes adjusting tire pressure a bit more
    complicated if you filled your tires from a compressor without first
    blowing all the moisture out of the receiver...?
    Tire shops claim that filling your car's tires with nitrogen will
    somehow make them run cooler and last longer. Actually the nitrogen in
    the tanks they use is DRY nitrogen.
    But, if you start out with moist air inside your tire, and you inflate
    it to the operating pressure with dry nitrogen, how is that supposed
    to get residual moisture out of the tire?
    I was doing pressure decay tests on stainless steel ducting in a high
    temperature oven as part of a qualification tests for Yokohama.
    They had bought a license from our company to make the pneumatic
    ducting for F-15's in Japan, so I had to run the series of tests.
    Pressure decay tests are reasonably simple. You pressure the test
    article with compressed air and put the part into the oven and see how
    long it take for the pressure to decay down to some level.
    Problem was, the air pressure wasn't decreasing as the part heated, it
    was increasing wildly. I had to use dry nitrogen to run my tests.
    Potage St. Germaine, Mar 25, 2007
  11. This is complete bollocks.
    Think air suspension. Think air fork conversions. They manage fine.
    Think that even if there was that much pressure change (and there
    isn't), if the fork seals allow the air past the seals as you claim,
    *the fucking pressure would equalise*.
    Think rear shocks. If what you post is true, then rear suspension units
    would piss oil as well. They're the same units, effectively.
    Christ, you post some crap.
    The Older Gentleman, Mar 25, 2007
  12. I actually can't figure out whether he's taking the piss out of Green
    Pea or whether he believes this. If he's gently trolling GP, he's doing
    it superbly.
  13. Tyre pressures should always be checked cold, for precisely this reason.
    Also, I seriously doubt that you could tell the difference between a
    tyre at precisely the correct pressure and one 2psi over-inflated.
    Possible, but unlikely.
  14. Yamaha put tire valves in the fork caps on their first 250cc DT-1
    Enduro because they were concerned about air leaking past the fork
    seals, causing a buildup of pressure that resulted in excessive air
    spring effect.
    Riders were advised to "burp" the forks when they
    moved to a higher elevation and also when they were riding over rough
    terrain.
    My GSXR sat in the garage unridden for about two years while I was
    recovering from a work injury.
    When I finally rolled it out of the garage, there was
    fork oil running from the seal down the slider and making a tiny
    puddle.
    The oil level in the forks couldn't have been as high as the oil
    seals.
    I was left with two possibilities.
    The first is that air pressure changes cause fork seals to weep.
    The other possibility is that my tom cat pisses fork oil...
  15. You don't think the world has moved on, in terms of construction and
    seal technology, since then?
    And were it even true, then the difference in pressure would be tiny.
    And the fact that this advice is no longer given suggests that it was
    about as useful as the old Britbike advice to remove your piston after
    the first 500 miles and sand down the high spots with wet&dry paper.
    Christ, I cannot believe you can be this stupid. Seals dry out, if left
    over time. They harden fractionally. I've had it happen. That's what
    happened to yours.
    My local dealer said it's a common occurrence with bikes that sit in the
    showroom for ages. He now does a tour of the showroom every month or two
    and pumps the forks of the bikes just to get some oil on the seals. It's
    a good tip, and I do it now, as some of my bikes hibernate for months.
    And I see you've conveniently ignored my reference to air suspension.
    I've ridden bikes with air-assisted forks across mountain ranges, and I
    can assure you you'e talking crap.
    Look, for ****'s sake, stop posting your perceived wisdom as truth. If
    you really want to help newbies, post something accurate, as you do from
    time to time.
  16. Masospaghetti
    billybob² Guest
    Sorry OG, I was taking the piss out out of him. When some one comes up with
    something so far fetched, it is easy to come back with double. I will
    attempt to be a little more 'slack' next time. ;-)
    billybob², Mar 25, 2007
  17. Masospaghetti
    John Johnson Guest
    More to the point, B-12 has somehow missed the fact that in "RWU" forks,
    the air is _between_ the oil and the seals, so it's a bit of a mystery
    how changing air pressure could possibly force oil past the seal. Now
    then, if the forks got moved when B-12 moved the bike, and if the seals
    had dried out in the meantime...oh wait, that explanation doesn't
    involve air pressure. It can't be right. ;-)
    Later,
    John
    John Johnson, Mar 25, 2007
  18. Heh. It's less far-fetched that Green Pea's "Europe buys diesel cars
    because they don't have earthquakes" proposition.
    Nicely done, sir.
  19. Bwaaaahhaahaha!
    Yes, I missed that.
    Of course, USD forks will leak like sieves. But not in Australia.
  20. It has also moved along in damper valving technology. What Japanese
    suspension engineers perceived as excess airspring effect from leaky
    oil seals was actually caused by the velocity sensitivity of fixed
    orifice damper rods in some of their forks.
    Why they included "burp" valves in forks that
    already had compression blow off valves in them may remain an unsolved
    mystery. GOK what engineer made that decision.
    Motorcycles emanating from Russia, China, and India are usually just
    as crude as you describe.
    And what's your theory about how the fork oil rose up out of the
    bottom of the sliders? The fork oil just barely covered the top of the
    damper rods and that was 4 or 5 inches below the level of the oil
    seals.
    You don't have "mountain ranges" in England, you have mole hills like
    the Cotswolds. OTOH, I can ride from below sea level to over 10,000
    feet around here and those two points are within 30 miles of each
    other.
    And, if you're riding a motorcycle with around 7 PSI over ambient in
    the forks, that's almost half an atmosphere over ambient pressure. Not
    much air at 14.7 PSI is going to past the seals to get into a fork
    pressurized at 21.7 PSIA.
    OK, and you should stop being so sarcastic with the
    newbies and stop telling them to go RTFM.
