Cleaning Bikes (Again)
Discussion in 'Bay Area Bikers' started by jacksf, Feb 22, 2004.
  1. jacksf
    jacksf Guest
    I sort of remember on the last thread about cleaning bikes using WD40 as
    a cleaner? Is that correct? If so, do you just spray it on and then
    scrub with a stiff brush? How do you wash it off? Seems it would put a
    coat of oil that would be difficult to remove.
    Sorry about all the questions but a friend shamed me about the condition
    of my bike and have to now start spending more time cleaning the beast.
    TIA
    Jack
  2. jacksf
    muddycat Guest
    For the chain. I use simple green on the rest with a soft brush for the
    wheels and farme.
    muddy
    Testing the limits of gravity since 1947.
    icq - 219328929
    muddycat, Feb 22, 2004
  3. I use WD40 as a tar spot remover on the painted aluminum engine casings of
    my BMW R1100RS. I wipe it off afterwards with a clean cloth. WD40 is
    mostly just kerosene, it doesn't have any real oil in it. Any residue it
    does leave seems to wipe off easily enough, and keeps dirt from sticking
    quite as firmly.
    John R Pierce, Feb 22, 2004
  4. jacksf
    Chuck Yerkes Guest
    Keroscene. Eats through most gunk, causes no harm to chains (o-rings),
    or rubber or plastic. Gets the nastry crap off the tire rims.
    WD-40 is mostly spray keroscene (ok, some extra chemistry, but...).
    But a gallon of keroscene is far far far cheaper. i dump some in
    a tupperware thing and apply with a rag and keep the rag in another
    tupperware thing once it's aired a bit).
    (storage and disposal should be done responsibly, blah blah blah,
    don't dump it into sewers -> bay).
    And it makes you smell all manly.
    Chuck Yerkes, Feb 22, 2004
  5. No, wd-40 does wonders on all kinds of parts. It'll take sticker goo off
    plastic, cleans up chain goo off the rubber swingarm sliders, road grime
    off engine parts etc. Just wipe it off with a rag, or wash off with a good
    vehicle wash suds stuff. Old toothbrushes are a great tool, too.
    Another thing that works great on plastic surfaces is Plexus. Used to be
    hard to find, but now home improvement stores are selling it. Bodywork,
    helmets etc. Not really a wax, but it shines the plastic and leaves some
    kind of grime repelling film.
    Charles Stembridge, Feb 22, 2004
  6. jacksf
    Alex C//415 Guest
    "Protectall" is the $%#&! I have an excellent way of keeping my bike
    clean--too lame to ride it much, under a cover in the corner of the garage.
    Alex C//415, Feb 22, 2004
  7. jacksf
    Robin Guest
    Yeah, I use that on everything.
    Robin, Feb 23, 2004
  8. jacksf
    barbz Guest
    I used to use WD-40 on my boat motor when I was out of diesel. It
    definately helped prevent saltwater corrosion by leaving a protective
    film of light oil, and that was a 1940 Graymarine flat six. It was in
    beautiful condition when I sold the boat.
    barbz
    barbz, Feb 25, 2004
