Cleaning Aluminum Rims
Discussion in 'Motorbike Technical Discussion' started by Mastermech, Apr 11, 2004.
  1. Mastermech
    Mastermech Guest
    What does everyone use to clean their wheels? Mine could use a good
    cleaning but the mag cleaner for my truck says not to use on motorcycle
    wheels. Aluminum wheels by the way covered in chain lube and brake dust.
    Thanks..
  2. Mastermech
    Mark Olson Guest
    WD-40 on a rag works great for me.
    Mark Olson, Apr 11, 2004
  3. Mastermech
    Dan Carter Guest
    For a real chain lube mess, I use WD40 as Mark suggests. Don't spray it
    on because it can foul your brake pads. After wiping off the worst of
    the gunk, I use S100 (also sold as "Hondabrite").
    Some mag wheel cleaners are caustic. While good for unfinished metal,
    it can remove paint (including clear coat) and anodize. Worst case, it
    gets under the tire bead and creates porosity in the paint that produces
    a slow pressure leak that can be cured only by stripping and refinishing
    the wheel. It can also ruin bearing dust seals and get into the bearing
    itself.
    Dan Carter, Apr 11, 2004
  4. Mastermech
    Mastermech Guest
    Damn what a fast reply, I'll give it a try thanks!!
  5. Mastermech
    Les Guest
    Rain or snow a few times a year.
    Les, Apr 12, 2004
