Clattery, clat-tat-tatery. Errr, help!
Discussion in 'UK Motorcycles' started by AnyOne ForAPint, Oct 15, 2003.
  1. <fx: places cap in hand>
    The ol' faithful Fazer6 is starting to make disturbing clattering noises
    from deep within the engine in a "terminal soon" type of way. It's most
    noticeable when cold and keeps time with the rpms especially on a closed or
    neutral throttle. I assume this is "not a good thing" [tm]
    I'm thinking (or rather completely guessing) cam chain given the milage
    (50k) and the lack of any major servicing save the valve check at around
    28k. Looking in the HBoL all I see are scary pictures of engine internals
    in a spotless workshop with all the appropriate tools to hand. This does
    not describe the situation in my garage.
    With my current cash flow, taking it do a dealer (aka Cane stylee) to fix
    isn't an option so I'm going to have to spanner it myself. Ideas,
    suggestions, and offers of assistance all greatfully received.
  2. AnyOne ForAPint () wrote:
    : <fx: places cap in hand>
    : The ol' faithful Fazer6 is starting to make disturbing clattering noises
    : from deep within the engine in a "terminal soon" type of way. It's most
    : noticeable when cold and keeps time with the rpms especially on a closed or
    : neutral throttle. I assume this is "not a good thing" [tm]
    : I'm thinking (or rather completely guessing) cam chain given the milage
    : (50k) and the lack of any major servicing save the valve check at around
    : 28k. Looking in the HBoL all I see are scary pictures of engine internals
    : in a spotless workshop with all the appropriate tools to hand. This does
    : not describe the situation in my garage.
    : With my current cash flow, taking it do a dealer (aka Cane stylee) to fix
    : isn't an option so I'm going to have to spanner it myself. Ideas,
    : suggestions, and offers of assistance all greatfully received.
    I think the cam-chain on Fazers runs up the centre of the engine which
    means it's a much bigger job than engines which have the chain on the
    side. Personally I wouldn't dream of tackling somthing like this but I'm
    a complete mechanical numpty.
    Blair.
    '97 CBR600
    B.G. Finlay IT Services, Oct 15, 2003
  3. AnyOne ForAPint
    Cane Guest
    Think of the pennies you saved.
    .... is what you should've done.
    cane [at] ukrm.org ¦ fireblade, r30
    botafo t#50 f#03 YTC #15 bbb #6 apostle [kotl]
    New? http://www.ukrm.net/faq/ukrmscbt.html
    Rideout? http://www.horrible.demon.co.uk/botafof/
    "Brace yourselves ladies, I'm coming in dry"
    Cane, Oct 15, 2003
  4. AnyOne ForAPint
    With luck, as others have said, it sounds like the cam chain. My one does
    this when the chain needs adjustment (manual adjuster see). Seeing as your
    bike doesn't have a manual adjuster the chain is fucked. With good
    fortune, none of your valves or cam lobes are fucked either.
    Muck
    Bandit 600n(With added ducktape); CG125(MSOHPR)
    "I've got a CG125, and I'm not affraid to use it."
    DS#1 ; DOMO#1 ; SH#2 ; ICQ: 166144431
    Remove _TEETH_ to e-mail
    Muck, Oct 15, 2003
