Clanking Triumph
Discussion in 'UK Motorcycles' started by Keiff, Dec 21, 2006.
  1. Keiff
    Keiff Guest
    Got a 1999 Triumph Daytona 1200 SE, just had one of 2 ignition coils
    replaced and the slave cyclinder on the clutch rebuilt after it broke
    Recently when I start the bike, I press the starter button and there is
    a nasty clanking noise, that seems to be coming from the crank case,
    bike eventually fires and runs perfectly, but it sounds horredendous
    till it starts.
    If you put your hand on the casing, you can actually feel the knocking
    Anyone got an idea
    Keiff
    Keiff, Dec 21, 2006
  2. Keiff
    MikeH Guest
    Is there a spanner on the garage bill?
    MikeH, Dec 21, 2006
  3. Keiff
    Charlie Guest
    Sprag clutch? If so, phuqt. If so, either expensive at a dealer or a
    *very* tricky job to do yourself.
    Charlie, Dec 21, 2006
  4. Keiff
    Spete Guest
    Starter clutch. Mine is going to be replaced next week
    Spete, Dec 21, 2006
  5. Keiff
    TOG Guest
    Starter motor clutch. Known weak spot on Triumphs, although I thought
    they'd modded them by 1999.
    As Triumph based their early engines on Kawasakis, replacing the clutch
    is a massive job. Engine out, and expect a bill of at least £800 from
    a dealer.
    TOG, Dec 21, 2006
  6. Keiff
    On 21 Dec 2006 08:31:09 -0800, TOG@toil,
    <wince>
    Yeouch.
    Pip Luscher, Dec 21, 2006
  7. Keiff
    says...
    Wot he said.
    You can find out more about it, or even what's involved in replacing it
    from the guys at www.t595.net
    Apparently it's a common enough problem with pretty much all Triumphs,
    even the more recent ones.
    Lozzo, Dec 21, 2006
  8. Main culprit is the battery. They fit small ones to the Trumfs, and when
    they get a bit tired, especially in cold weather, they start to struggle
    to turn the lump over, and then it kicks back against the starter
    clutch, and *bang*.
    Solution: always make sure the battery is fighting fit.
    The Older Gentleman, Dec 21, 2006
  9. Keiff
    The Older Gentleman says...
    Mine is always on the Optimate when I know it won't be used for a few
    days, the alarm drains it otherwise.
    I just put a Bandit 1200 YTX12-BS battery on the Bandit, standard for
    the 600 is a YTX9-BS. There's room for a YTX12 if you pull the huge foam
    block from under the YTX9 and the Bandit 1200 runs the same alternator
    and charging system, so in it went to give me a bit more starting power
    in winter.
    Lozzo, Dec 21, 2006
  10. Keiff
    and fit a Hawker Odyssey AGM battery when the OE packs up. The construction
    apparently gives a battery that a) discharges very little in storage and b)
    delivers max Ah more readily, especially when cold.
    Said battery has eliminated the ABS initialisation issues I had with the OE
    Bosch jobbie. Costs £68, which is a little more than a Yuasa and less than
    an OE replacement, from http://www.cheshirebatteries.co.uk/
    http://www.odysseyfactory.com/ - although the fitment guide only shows the
    Daytona 600. Odd: sure to be a PC680 or PC310 as most are one of the two
    wessie, Dec 21, 2006
  11. Keiff
    As others have said it's the sprag (starter) clutch. It was
    under-engineered in pre mid-90s models, but later models have also been
    known to fail.
    Many people including myself have convinced Triumph to cover the parts
    cost well after the warranty expired, but that will depend on it having
    a full main dealer service history, & on your letter writing ability.
    Even if you manage that, you're still looking at a £400+ bill for
    labour (it's an engine out job).
    When you get it fixed, make sure you keep the battery fully charged to
    stop it happening again. Also be firm with the starter button - don't
    'stab' it & release it quickly - keep it engaged for at least a couple
    of seconds or until the engine starts.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Dec 22, 2006
  12. Keiff
    Keiff Guest
    Thanks to everyone who has responded, while its depressing to get the
    same answer from everyone thus confirming I have a big job ahead, the
    rapid response was excellent.
    Bike now booked in for the new year to get the f'ing clutch replaced
    Cheers All and Merry Xmas
    Keiff, Dec 22, 2006
  13. Keiff
    Keiff Guest
    Cheers, I have a Yuasa in at the moment, but have moved house and the
    the bike is outside in the cold at the moment, from the rest of the
    comments on the forum appears to be a cause as normally when it was in
    a garage it was always on the Optimate.
    Oh well expensive lesson learnt
    Keiff, Dec 22, 2006
  14. Keiff
    TOG Guest
    You're talking about your 1150GS here, right? Because I'll bear this in
    mind for when I need a replacement for my ABS-equipped K's battery. Ta.
    TOG, Dec 22, 2006
  15. Keiff
    MikeH Guest
    Thanks for that.
    My ABS has just started to winge on cold mornings.
    MikeH, Dec 22, 2006
  16. Keiff
    Scraggy Guest
    My LT has just failed the start test, in spite of being on the optimate. I
    will now press send and then phone this bunch.
    Scraggy, Dec 22, 2006
  17. Keiff
    Scraggy Guest
    Update, they are out of stock PC680, awaiting delivery. I'm on their list.
    Present price ca £58 inc they are expecting a price rise (10-14%) due to
    shortage of lead.
    That'll be Iraqistan then.
  18. Keiff
    Get a Westco from http://www.motorbikebatteries.co.uk/ Also AGM &
    jolly good.
    Krusty
  19. Keiff
    Scraggy Guest
  20. Keiff
    Yes.
    wessie, Dec 22, 2006
