Chuffed!
Discussion in 'UK Motorcycles' started by Linger, Jan 19, 2004.
  1. Linger
    Linger Guest
    Worth a clean innit. It might be, it's quite an important part.
  2. Linger
    Donegal Paul Guest
    That's the CB sorted then, Im pretty sure it'll be ready for an MOT soon!!
    Brakes are all rebuilt and bled, tanks back on, seats back on, etc,
    battery's charged and its running!
    Only thing is that it seems to be revving a bit high for some reason :-(
    Idle was adjusted and ive readjusted it but still runs too high and then
    sometimes settles down, blipping the throttle seems to produce a bit of a
    pop, not a backfire but im wondering if all this is related to the air
    filter, its not full of shit, but its not exactly clean either.
    Could it be that simple?
    Donegal Paul, Jan 19, 2004
  3. Linger
    deadmail Guest
    Air leak at the inlet?
    Carb synchronisation?
    deadmail, Jan 20, 2004
  4. Linger
    Donegal Paul Guest
    Cant imagine so as before i took off the seat and tank all was running well
    and intact but ill double check tomorrow JIC
    Not a fecking clue, dont know whats involved at all or the symptoms. On the
    lammy, the carbs synced if when you apply the throttle the scooter goes
    forward :)
    Again though, what could have put them out of sync if when it was running it
    was fine as above?
    Donegal Paul, Jan 20, 2004
  5. Linger
    deadmail Guest
    Ah well, just an idea.
    I'm presuming it's a twin, in which case fiddling about with it taking
    it off the bike would cause it to go out of synch.
  6. No. It means you haven't got the pilot screw adjustment right, and it's
    running too lean at idle.
    The Older Gentleman, Jan 20, 2004
  7. Linger
    Donegal Paul Guest
    'Tis a twin, ok then so that's a possibility
  8. Linger
    Donegal Paul Guest
    "The Older Gentleman" said to Donegal Paul
    Ah, ok, anyone know offhand then how it should be set?
    Sorry guys :-(
  9. Linger
    RTFM.
    Ace, Jan 20, 2004
  10. Donegal Paul wrote
    It will either be 1 and a half or 2 and a half turns out. Consult yer
    BOL for the exact details.
    If you haven't got details then you can always, assuming you are working
    on the basis it is too lean:-
    Screw the jet home counting the number of turns as you go and then screw
    it out again to half a turn less and then in quarter turn increments
    open and try. When you get it open to about 5 turns and there is ****
    all difference then you can be fairly certain it wasn't that.
    steve auvache, Jan 20, 2004
  11. Linger
    Donegal Paul Guest
    eh?
  12. Donegal Paul wrote
    RTFF
  13. Linger
    Donegal Paul Guest
    "Dr Ivan D. Reid" said to Donegal Paul
    I have to admit, I had read pilot screw as pilot jet and thought there must
    be something vastly different in these carbs compared to the lammy.
    Think that was a bit of a senior moment!
    OK, I know exactly now what you guys meant so had a look at the carbs and Im
    buggered if I can find the pilot screw, ill dig out the cb250 manual for
    reference though.
    Still, as it was running, I thought I would bring it out for a quick spin up
    and down our street a bit and while it was running ok up to 40mph, if
    throttle was applied then it seemed to want to die which on the lammy would
    suggest some form of air intake problem :-/
    Oh, and those front brakes are rebuilt but spongy as **** so I guess I need
    to bleed the buggers.
    While Im here is there an easy way to bleed brakes?
    What Im wondering is is it worth using those systems that are supposedly
    hands free?
    As its twin discs up front then do you bleed each calliper in turn or what?
    Anyone?
  14. Attach bleed pipe to nipple. Undo nipple half a turn or whatever it
    takes, squeeze brake lever, shut nipple, release lever. repeat ad
    anuseam until bubbles stop coming out of the pipe. Change the brake
    fluid, topping up the master cyclinder reservoir as you go. when the
    clean fluid comes through the pipe, stop.
    Don't let the level in the reervoir fall too low, or you'll start
    pumping air again.
    Don't release the brake lever with the nipple open, or it'll suck in air
    at that end.
    Yeah, they're useful, but the old-fashioned way works fine.
    Yes, just that.
    Top tip - get a blowlamp and apply heat, a lot of heat, to the nipple
    before you put a spanner on it to undo it. They're notorious for
    seizing, and snapping off otherwise.
  15. Linger
    anuseam until bubbles stop coming out of the pipe.[/QUOTE]
    You undo/redo the nipple every squeeze? Jeezus, talk about making hard
    work of it.
    You can just put the end of the bleed tube into a jar of fluid to stop
    it sucking air back in, shirely?
    Ace, Jan 21, 2004
  16. Ace wrote
    The basis of a one man operation bleeding tool. The rest of the
    components are, I believe, a screw and a knife. If I recall correctly
    you bung the screw in the tube and just above it make a very small cut
    in the tube. This you put into your jar of fluid.
    steve auvache, Jan 21, 2004
  17. Yes, except that it then sucks in the old fluid and it could getback
    into the system.
    Besides, just pumping the brakes without shutting off the nipple will
    simply pump-suck in-pump suck in etc ad nauseam.
    The Older Gentleman, Jan 21, 2004
  18. Dr Ivan D. Reid wrote
    I believe, I believe
    Neat. Does it work for bleeding brakes?
  19. Dr Ivan D. Reid wrote
    Not gonna be that much back pressure is there. The one atmosphere from
    the atmosphere and however much suck there is in a brake master
    cylinder.
    I think a 21st century take young Bunsen's idea might be a goer.
  20. Linger
    steve auvache said...
    I think my Mytivac works just fine.
    http://www.mityvac.com/
    Lozzo, Jan 21, 2004
Similar Threads
Loading...
