Chinese pork belly recipe, long and foody.
Discussion in 'UK Motorcycles' started by Gingerposer, Dec 27, 2004.
  1. Gingerposer
    Gingerposer Guest
    Here, as I can't be arsed doing it any other way.
    Ingredients, to serve 4-6:
    1*1.5 kg piece thick pork belly, with rind
    1 tablespoon Sichuan peppercorns
    1 teaspoon black peppercorns
    2 tablespoons Malden sea salt flakes
    2 teaspoons five spice powder
    2 teaspoons caster sugar
    1 quantity steamed greens in oyster sauce (see separate recipe detailed
    afterwards)
    steamed rice (see second separate recipe detailed further after!)
    Spike the skin of the pork with a fine skewer or larding needle as many
    times as you can, going through into the fat but not so deep that you go
    into the flesh. Then pour a kettle full of hot water over the skin, leave to
    drain and then dry it off well.
    Heat a dry, heavy based frying pan over a high heat. Add the Sichuan and
    black peppercorns and shake them around for a few seconds until they darken
    slightly and start to smell aromatic. transfer them to a spice grinder and
    grind to a fine powder. Tip them into a bowl and stir in the sea-salt, five
    spice powder and sugar.
    Turn the pork flesh side up on a tray and rub the flesh all ver with the
    spice mixture. Set aside and leave to cool for 8 hours or overnight.
    Preheat oven to 200c/400f/gas 6. Turn pork skin-side up and place on a rack
    resting on top of a roasting tin full of water. Roast the pork for 15 mins,
    then lower oven temp to 180c/350f/gas 4 and roast for a further 2hours,
    topping up the water in the roasting tin now and then when necessary.
    Increase oven temp once more to 230c/450f/gas 8 and continue to roast the
    pork for a further 15 ins. Then remove from oven and leave it to cool. It's
    best served warm
    Cut the pork into bite-sized pieces and arrange them on a warmed platter.
    Serve with the chinese greens in oyster sauce and steamed rice.
    Steamed chinese greens:
    cut 8-12 small heads of pak choi lengthways into quarters and place in an
    opened-out petal steamer.Lower into a shallow pan containing about 1 cm of
    simmering water, cover and steam for about 3-4 mins or until tender.
    Meanwhile, mix together 2 teaspoons of sunflower oil, 1 teaspoon sesame oil,
    4 tablespoons oyster sauce and one tablespoon of dark soy sauce in a small
    pan and leave to warm through over a low heat. Transfer the pak choi to a
    warmed serving plate, spoon over the sauce and serve.
    Steamed riceRinse 350gm of long grain or basmati rice in cold water until
    the water runs relatively clear. Drain, tip into a 20 cm heavy-based
    saucepan and add 1/2 teaspoon of salt and 600 ml of boiling water. Quickly
    bring back to the boil, stir once, cover with a tight-fitting lid and reduce
    the heat to low. Cook basmati rice for 10 mins, ling grain for 15. Uncover,
    fluff up the grains with a fork and serve.
  2. Gingerposer
    Catman Guest
    You utter fucking *star*
    Next time you're down here, please let me know for your choice of beverages.
    www.cuore-sportivo.co.uk
    Catman, Dec 27, 2004
  3. Gingerposer
    Ben Blaney Guest
    Obviously he's a repressed homosexual.
    Ben Blaney, Dec 28, 2004
