Cheese bolts
Discussion in 'UK Motorcycles' started by Molly, Nov 24, 2004.
  1. Molly
    Molly Guest
    Why oh why do manufacturers insist on making exhaust manifold bolts
    out of Brei.
    Gareth's bike had a problem so I told him he could borrow the GS. Five
    minute later he called to tell me that it's vibrating like crazy and
    had no power.
    First thought that he revved it like crazy from cold (as he does) and
    bent a valve. A quick compression test with my thumb over the spark
    plug hole showed no compression on the LH cylinder. However, I could
    see the valves opening and closing quite merrily when I cranked the
    engine, but no sign of the piston pushing it's merry way up. So off
    with the rocker covers and head. This is where I find the cheese
    exhaust manifold bolts. So, it's either weld a bolt to the rounded bit
    or drill them out. Why do I get a feeling that this is not going to be
    a straight forward piston swap?
    Molly
    "Kneesliders Sponsored by Cane"
    "Gower School" By Appointment".
    GSX-R1000 (better), Triumph Thunderbird, GS500, GHPOTHUF#27
    TGF, UKRMFBC#7, Two#24, BOTAFOF#11, YTC#9, GYASB#1. SbS#23.
    DFWAG#2, DS#2, DIAABTCOD#20. remove "thisbit" in the reply
    http://www.mollyg.net (our own endurance team)
    http://www.bikegirl.co.uk/ladies/racingladies.html
    "Nemo repente fuit turpissimus"
    Molly, Nov 24, 2004
  2. Molly
    Martin Guest
    Drill slowly and then heli-coil, anything else will be fruitless.
    Martin:
    VTR1000 Firestorm
    Martin, Nov 24, 2004
