Cheap welder
Discussion in 'UK Motorcycles' started by Eddie, Sep 18, 2006.
  1. Eddie
    Well, it wouldn't, would it? It would rather annoyingly switch itself
    off before reaching critical mass - just in the middle of the day's
    best bead - and then refuse, adamantly, to restart until you'd got
    cold, the steel had got cold - and your rod had got damp.
    Cheapshit welders are shit pretty much because they're cheap, Eddie.
    They have crap power supplies and won't sustain a decent arc at a
    decent amperage because the power supply just won't take it. Splash
    out a few more quid and get the dilithium crystal model and you'll
    have no problems.
    Pip, Sep 18, 2006
  2. Eddie
    mb Guest
    ITYF TIG needs a bit more skill than either.
    You can weld razor blades to thin air, thobut.
    mb, Sep 18, 2006
  3. Eddie
    Eddie Guest
    I'd generally agree about cheapshit anything, but Aldi's stuff is almost
    always much better quality than you'd expect for the price.
    It's got a 3-year warranty; how bad could it be?
    It is a bit odd about the plug, mind...
    Eddie, Sep 18, 2006
  4. Eddie
    The fact that they don't mention the duty cycle at all should tell you
    something...
    Timo Geusch, Sep 18, 2006
  5. Eddie
    antonye Guest
    Just a guess but it may be because the felt-tip fairy that did the
    web page knows **** all about how to sell welding equipment?
    antonye, Sep 18, 2006
  6. Eddie
    Eddie Guest
    I would expect so, and I would also expect that it'll say on the box,
    which I'll be able to inspect before I purchased said item.
    Besides which, neither Screwfix nor Machine Mart specify duty cycles on
    their websites; does that mean their stuff's shit, too?
    Anyway, what sort of duty cycle should I be looking for, assuming it
    does say on the box?
    Eddie, Sep 18, 2006
  7. Eddie
    deadmail Guest
    Heh, I find myself quoting this (or something like it) on an almost
    weekly basis to various people in my team. Sometimes I have to say it
    to myself.
    Work really fucks you up, it turns the reasonable into the unreasonable,
    the healthy into the unhealthy and the power crazed into the satisfied.
    deadmail, Sep 18, 2006
  8. See if you can wangle a go on a pro machine and you'll find it much
    easier to learn. Same goes for arc.
    Learn on a good machine and you can easily cope with the shite that
    passes for DIY stuff.
    Grimly Curmudgeon, Sep 18, 2006
  9. Perhaps it's a 16A supply needed. Unusual for a diy welder, but depends
    on the characteristics.
  10. 100% would be marvellous, but for a cheapy diy type 33% might be all you
    get. 50% you could work with and if it's fan-cooled anyway the cycle
    might be higher than that. I fitted a fan to a cheapy arc welder and
    upped the duty cycle to something useable.
    Grimly Curmudgeon, Sep 19, 2006
  11. Eddie
    I just looked there too - and you're right, dammit!
    !0% is bad (one minute working in ten), 90% is good (nine minutes
    working in every ten).
    Having compared specs as far as possible between the Aldi nad MM
    offerings, this Aldi job appears to be on a par with the bottom of the
    'pro' range at MM, as it has a cooling fan. The fan would of course
    extend the duty cycle noticeably, prolly to 60 or 70%, which is more
    than adequate for an amateur interested in modelling chickenshit on
    steel.
    Pip, Sep 19, 2006
  12. Eddie
    Eddie Guest
    It's an unfortunate habit of mine.
    Right. As I haven't welded anything for, oh, about 20 years, I can't
    imagine I'll be able to do 9 minutes constant welding anyway, so I guess
    even 50-60% would be bearable.
    Chickenshit on steel? Sounds like a piece of modern art; I wonder if I
    could flog it to the Baltic?
    Eddie, Sep 19, 2006
  13. The printed brochure is much the same as the web-page so no more
    info there. Note the little label saying "Turbo Fan-Cooled for extended
    duty cycle", they must have paid some attention to it (even if it was,
    "Hey Klaus, stick a fan on the Speisegerate and we can claim extended
    duty-cycle!").
    The bit about the plug's puzzling -- usually Aldi stuff comes with
    UK _and_ European power leads.
    Dr Ivan D. Reid, Sep 19, 2006
  14.
  15. Eddie
    antonye Guest
    To the NHS, surely?
    antonye, Sep 19, 2006
  16. Eddie
    Eddie Guest
    Eh? You've lost me there... are you trying to be subtle?
    Eddie, Sep 19, 2006
  17. Eddie
    antonye Guest
  18. Eddie
    Eddie Guest
    Eddie, Sep 19, 2006
  19. Eddie
    Beav Guest
    Don't play with one, GET one. If you play with one, you'll give up before
    you get to the point where you can do a reasonable/good job and it's a shame
    when that happens.
    TIGing takes a bit of practice but if you can stick weld, it's not a huge
    leap.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Sep 19, 2006
  20. Eddie
    Beav Guest
    Bruce Dickinson landed the Shuttle simulator first time, so I reckon he must
    be a fucking ace welder. I bet he carries his mask around all the time too.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Sep 19, 2006
