Cheap or free PCB CAD S/W & schematic capture
Discussion in 'UK Motorcycles' started by Pip Luscher, Jan 13, 2011.
  1. Pip Luscher
    On Mon, 17 Jan 2011 13:41:31 +0000 (UTC), Dylan Smith
    [of gEDA]
    gEDA looks the best option so far. I'm far, far too lazy to start
    writing special scripts unless I have to, though.
    So far, I've got Windows 7 and Debian Lenny loaded. The basic
    dual-boot went remarkably easily: just install Windows and then
    install Debian disc 1. I'm probably not making best use of the two
    HDDs but I'll only worry about that if either system really crawls.
    What hasn't gone well has been enabling Internet access: Win7
    complains about a modem error, even though the other PC works fine.
    I haven't tried Debian yet. It might just be me getting my passwords
    etc. confused, or maybe it's using DHCP that's hard-coded to a
    particular MAC or something like that. Actually, I might
    install/fire-up Wireshark and have a look, but I'll try out Virgin
    Media's help first.
    It's a minor problem because I won't generally be using the second PC
    on-line to start with; it would simply make uploading stuff a bit less
    fiddly. Oh, and registering Windows would be easier.
    Pip Luscher, Jan 19, 2011
  2. Pip Luscher
    spike1 Guest
    Try debian first.
    If debian works (which it should) at least then you know to concentrate on
    the windows side of things rather than the router.
    Not to mention downloading things from the debian repositories.
    | | Windows95 (noun): 32 bit extensions and a |
    | | graphical shell for a 16 bit patch to an 8 bit |
    | Andrew Halliwell BSc | operating system originally coded for a 4 bit |
    | in |microprocessor, written by a 2 bit company, that|
    | Computer Science | can't stand 1 bit of competition. |
    spike1, Jan 20, 2011
  3. Pip Luscher
    Ivan D. Reid Guest
    Just noticed this on my work PC as well. It _does_ export Gerber
    files:
    http://www.freepcb.com/
    Ivan D. Reid, Jan 20, 2011
  4. Pip Luscher
    Well, when I said, upload, I actually meant download.
    Anyway, sorted it last night.
    Wireshark in Windows revealed a mix of IPv4 & IPv6 packets, many of
    the latter seeming to be the PC (I didn't bother decoding the address)
    bleating out the same query over and over again. Taking a wild guess
    (I know even less about v6 than I do about v4), I just disabled v6 on
    the NIC, and it sprang into life.
    I also found that the cable modem has to be power-cycled whenever I
    swap over PCs; it then takes a minute or so to wake up. My guess is
    that it (or maybe an upstream server) retains the DHCP lease even if
    the PC is disconnected and it can't cope with more than one at a time.
    I then tried Debian: after enabling the NIC and ensuring that it was
    set to use DHCP, that "just worked", too. I've still to sort out the
    package manager setup: it keeps asking me to insert CDROMs. At work we
    get a nice installation disc that has all this stuff pre-configured.
    Pip Luscher, Jan 20, 2011
  5. Pip Luscher
    OK, ta. If I don't get on with gEDA then I'll give it a look.
  6. I love it when a plan comes together
    PipL on Debian, Jan 20, 2011
  7. Pip Luscher
    davethedave Guest
    Just wait till you do the apt-get update to fucked bit. :)
    davethedave, Jan 21, 2011
  8. Pip Luscher
    Haven't had a problem yet at work, though to be fair I've only been
    using Debian for a year or so: prior to that my workstation was a
    Fedora box.
    Pip Luscher, Jan 21, 2011
  9. Pip Luscher
    davethedave Guest
    It's like Ronseal. It does what it says on the tin. Testing is often a bit
    shaky and can in fact be a bit testing. Stable is stable indeed, but is a
    little late in getting the nice toys.
    I don't really get on with RPM based flavours. All a matter of taste. I have
    had Debian systems around the house for more than "eek!" years now. Which
    makes me feel old. :(
  10. Pip Luscher
    Yeah, I chose Lenny because I'm not one for the bleeding edge myself.
    I have yet to be frustrated by a a lack of toys.
    Debian's kind of grown on me.
    Pip Luscher, Jan 23, 2011
