Cheap or free PCB CAD S/W & schematic capture
Discussion in 'UK Motorcycles' started by Pip Luscher, Jan 13, 2011.
  1. Pip Luscher
    Re subject: I've a vague idea that this has been done recently, but
    Dr. Evil stole my Google Mojo.
    Are there any such things? Free is good but it must be possible to
    enter a circuit diagram at one end, allow me to lay out a simple
    doube-sided (four layers would be nice, mind) PCB and then produce
    moderately standard Gerber files will do.
    TIA HAND etc.
  2. Pip Luscher
    JB Guest
    TinyCAD (free) or Proteus (demo)
    JB, Jan 13, 2011
  3. Pip Luscher
    Dan L Guest
    You can download a free CAD 2D program off the Siemens website
    Dan L, Jan 13, 2011
  4. Pip Luscher
    Ivan D. Reid Guest
    I've got something like that installed at work; I'll try to remember
    to look up the names tomorrow (e-mailing myself now...).
    Ivan D. Reid, Jan 13, 2011
  5. Pip Luscher
    rick Guest
    If it's a one off simple PCB send the circuit to me - I've got **** all else
    to do with my copy of Boardmaker :)
    Otherwise, I believe RS are offering a free PCB layout package or if there
    aren't many component/nets there's a free version of Vutrax (steep learning
    curve though).
    rick, Jan 13, 2011
  6. Pip Luscher
    Ta, but the plan is for it to be both a DIY DSP project and a CV
    builder. After today, I sense a career change coming on.
  7. Pip Luscher
    spike1 Guest
    gEDA seems pretty fully functional for schematic capture and even simulation
    iirc. It's the most fully featured electronics suite in the ubuntu
    repositories at any rate. I imagine it's also available for windows...
    There's also another one in ubuntu called Eagle, again, dunno about windows.
    spike1, Jan 13, 2011
  8. Pip Luscher
    JB Guest
    What you like doing PIC firmware in C and assembler? Bit of digital design,
    mainly PICs talking to CMOS camera chips, bit of multi-drop RS485, I2C,
    possibly a little analogue from time to time?
    We may have an opening as they say.....
    Drop me an email jmbyrne_AT_greenyonder.co.uk* if you do have a current CV.
    Cheers,
    JB
    *changing green to blue obviously.
    JB, Jan 13, 2011
  9. Pip Luscher
    Thanks, doesn't have to be Windows-specifc. I do have a laptop with
    Ubuntu installed and a currently OS-free PC that could go either way.
    Or both, if I can be arsed to figure out yet again how to dual-boot
    it. I'ev a vague memory that says that Windows needs the primary boot,
    err, thingy. See, it's been that long since I last did it.
  10. Pip Luscher
    Thanks.
  11. Pip Luscher
    That rings a bell. Thanks.
  12. Pip Luscher
    Noted, ta.
  13. Pip Luscher
    Pete Fisher Guest
    Grub about a bit on google.
    | Pete Fisher at Home: |
    Pete Fisher, Jan 13, 2011
  14. Pip Luscher
    Ivan D. Reid Guest
    Unless you want to get fancy, it's best to install Windows first,
    then Linux on top, letting grub take control of the MBR. If you need to
    blow Linux away later, the Windows install disk lets you do an MBR
    recovery. Make sure you have enough partitions set up before starting,
    of course.
  15. Pip Luscher
    That sounds fun and I appreciate the offer.
    Unfortunately, with my current employer, I've spent the last four
    years doing pretty basic scripting & produciton support of consumer
    products[1]; it's been a few years since I've done any PIC stuff, or
    C and assembler, so I'll be on a bit of a re-learning curve for the
    next few weeks at least. But yes, the plan is to use a DSPic.
    I'm also pretty much limited to commuting from the Newmarket area.
    [1] I was interviewed for one job, but when I showed up for work, on
    the very first week, I was hijacked by a more senior manager to do
    something completely different and eventualy the original job sort of
    evaporated.
  16. Pip Luscher
    Thomas Guest
    I started out doing architectural drafting, then moved to CAD. I got a
    job in a service bureau doing CAD for a variety of companies. Same
    skills, different disciplines - civil, mechanical, architectural, and
    electrical. When the company folded, I needed to decide what to do.
    There were no jobs in civil engineering. Architects made good money
    only after years of shit, and there are so many big egos to deal with.
    Mechanical made good money, you could see what you were designing, and
    the people were normal. Electrical was terminally boring, the
    engineers were geeks, and you couldn't tell the difference between a
    game controller and a nuclear trigger. Mechanical was berry, berry
    good to me.
    Thomas, Jan 14, 2011
  17. Pip Luscher
    JB Guest
    Good skills like these are always in demand. Nice to see someone prepared to
    get stuck into hands-on design at home too.
    We've used a few contract engineers working from home on various projects.
    That seems to be the norm now. The 9-5 lab or offfice based guys are often
    _not_ the best.
    BTDT!
    If you need a good electronics assembly firm to make your boards, speak to
    Rory Gavin at Freedom Electronics in Newbury, Berks. A *top* bloke to deal
    with. 01635 277688. Mention my name (John Byrne).
    cheers,
    JB
    JB, Jan 14, 2011
  18. Pip Luscher
    Ivan D. Reid Guest
    ExpressPCB and ExpressSCH (ematic) -- www.expresspcb.com
    Don't think it does Gerber though; the menu has Export DXF/bitmap
    drawings. There's an option to generate a "plot" (.PLT) file to manually
    submit an order to them, but whether that's a proprietary format or
    not I cannot say.
    Ivan D. Reid, Jan 14, 2011
  19. Pip Luscher
    Adrian Guest
    I was doing precisely this yesterday. If you install Linux, then Windows
    - yes, Windows takes over the bootloader. But it's then fairly
    straightforward to use a liveCD (Ubuntu's on this machine) to reinstall &
    configure Grub to give you dual-boot.
    Looks techie - but follow the instructions, and it's straightforward.
    Takes about five-ten minutes.
    http://ubuntuforums.org/showthread.php?t=1581099
    Adrian, Jan 14, 2011
  20. Pip Luscher
    Dylan Smith Guest
    The gEDA collection of tools (gschem, gnetlist, gsch2pcb, pcb) work well,
    are Free (as in freedom and free beer), don't have any arbitrary restrictions
    on layers or PCB size, and produce gerbers/CNC drill files. PCB also has
    several options for PostScript export if you're home etching a PCB
    (PS bloat to fine tune the solder resist width etc. to match how you make
    the board).
    http://www.gpleda.org/index.html
    There is a bit of a learning curve. File formats are all plain text rather
    than some horrible binary blob, so you can also write scripts that
    can manipulate the files which gives a great deal of additional flexibility.
    The gEDA tools are a toolset rather than one big monolithic EDA package.
    I've made several boards with gEDA from 2 to 4 layers from quick things
    where I've just used PCB to make the pcb, and more complex things going
    from schematic capture in gSchem to layout in PCB.
    Dylan Smith, Jan 17, 2011
