charging system 81 cb750f
Discussion in 'Motorcycle Technical Discussion' started by b.don, Feb 28, 2005.
  1. b.don
    b.don Guest
    ive been fighting with this charging system for months now. ive
    replaced every part concerned so far with no sucsess. 1st from the
    wiring harness to voltage regulator/rectifier, there is current, aprox
    13v dc. ok. 2nd, from rr (black and white leads there seems to be no
    current (? should there not be the same 13v there going to the
    brushes?). 3rd, when bypassing the regulator and sending 13v dc
    straight into the black and white leads off the stator, i get up to
    aprox 50v ac out of the yellow leads. this i assume to be correct -
    stator and rotor ok (?). leaving me to think that the
    regulator/rectifier to be at fault. id believe this if i hadnt
    already gone through two of em trying to correct my problem. what am i
    over looking? am i somehow burning out regulators?
    b.don, Feb 28, 2005
  2. http://www.electrexusa.com/electrex_fault_finding.html
    Download the pdf (and acrobat reader if needed)
    If you're getting AC into the rectifier, sounds like the
    regulator/rectifier. When you bypass the regulator and send
    D.C. to the brushes, do you see a voltage increase at the
    battery ?
    Rob Kleinschmidt, Feb 28, 2005
  3. b.don
    b_don1 Guest
    when bypassing the two leads to the brushes, sending dc straight into
    the stator with the three yellow attached to the rectifier, yes, there
    is an increase at the battery. with everything pluged in right,
    nothing...
    b_don1, Mar 1, 2005
  4. It sounds like your *electrical* problem is with the regulator portion
    of the rectifier regulator, the wiring from the RR to the brushes, or
    maybe the RR case isn't properly *grounded* to the MC frame...
    It's also possible that the positive wire from the RR to the battery
    doesn't make good connection, is broken inside the insulation...
    That positive wire is probably the wire that does the voltage sensing
    for the RR...
    But you also seem to be having a difficulty with terminology. It's
    important to call a rotor a "rotor" and a stator a "stator" so you can
    describe your problem accurately and, if necessary, buy the right parts
    for replacement...
    An alternator that has brushes and slip rings is called an "excited
    field alternator". The voltage regulating part of the rectifier
    regulator senses battery voltage, and, if the battery voltage is low,
    it will send some *current* from the battery to one brush. That current
    will cause an electromagnetic field in the *rotor*, which is being
    turned by the engine, while the *stator* remains stationary....
    As the rotor turns, the electromagnetic field turns with it. The
    magnetic lines of force pass through the copper windings of the stator,
    inducing *voltage* in the windings. This causes an AC *current* to flow
    through the three yellow wires to the rectifier regulator where a three
    phase full wave rectifier bridge will turn the AC in DC that will
    charge the battery...
    A rectifier bridge such as I describe, has a total of six power diodes.
    The diodes are arrange in pairs, anode to cathode, and the three
    resulting pairs are arranged in parallel...
    AC current from each of the three yellow leads comes into a pair of
    diodes between the anodes and cathodes and current will flow toward the
    battery through one of the pair of diodes and be blocked by the other
    diode...
    If either one of a pair of diodes in the bridge is burned out, the
    rectifier output will be decreased by half...
    krusty kritter, Mar 1, 2005
  5. current, aprox 13v dc. ok. 2nd, from rr (black and white leads there
    seems to be no current (? should there not be the same 13v there going
    to the brushes?).
    Voltage and current are not the same thing, they aren't
    interchangeable. Lay persons can envision voltage as a force that
    *pushes* current through a circuit, but the physicists will argue back
    that current flowing through a circuit "uses up" the voltage...
    That argument doesn't matter, but you need to call current "current"
    and voltage "voltage". I suppose you are measuring *voltage* with your
    voltmeter because you say "13v dc"...
    You can have voltage at any point in your wiring, but current may not
    be flowing because the *circuit* isn't complete. Troubleshooting with a
    voltmeter consists of looking at a wiring diagram and probing the
    system at all points where you think there should be voltage. The
    component or wiring after the last point where you find voltage is
    suspect...
    Well, that takes a lot of *nerve*, or just total ignorance of
    electrical theory. I would have used a *flash light battery* to keep
    the current through the expen$ive rotor low...
    The resistance through the brushes and the slip rings on the rotor
    might be as low as 1 ohm, so you could be pushing up to 13 amperes
    (current) through the rotor, and the power dissipated by the rotor
    could be as much as the current *squared* times the resistance...
    That power could be as high as 169 watts! You know that you can't touch
    a 100 watt light bulb while it's lit. The rotor would be getting rather
    *hot* while you are taking your voltage measurements...
    So far as the 50 volts you're getting out of the three yellow leads is
    concerned, I would expect *more* voltage than that, if the stator is
    wound in the usual "wye" configuration, where all three neutral leads
    are connected and neutral isn't connected to ground. I would expect to
    see 70 to 100 volts from phase to phase to phase *open circuit* and NO
    voltage from any phase to ground. If you have AC voltage from phase to
    ground, that indicates a grounded stator winding...
    But, you didn't say what RPM you were doing the voltage test at.
    Usually 5000 RPM is specified for an open circuit test RPM...
    And, if you're telling us that you get 50 volts across the phases with
    all three wires *connected* to the RR, that shouldn't be possible,
    unless you have blown out diodes in the RR. An AC voltage connected to
    a battery through diodes is normally going to be pulled down to battery
    voltage...
    So, check out your wiring diagram and find out if the stator is "wye"
    wound, the electrical symbol will look like a Mercedes Benz emblem with
    curly arms...
