Changing front Sprocket?
Discussion in 'Motorbike Technical Discussion' started by SportBikes Canada, Feb 29, 2004.
  1. whats involved in changing a front sprocket.. is it easy... or should I have
    a dealer do it for me?
    www.sportbikes.ca
    Canada's SportBike Hangout
  2. SportBikes Canada
    Geribaldy Guest
    Probably easier to change the sprocket than to guess what bike you are on about :)
    Geribaldy, Feb 29, 2004
  3. haha
    mybad
    its a 98 YZF 600.. not R6
    and I want to go down a tooth in the front.. fron 15 to 14
    www.sportbikes.ca
  4. SportBikes Canada
    bowman Guest
    If you're asking, maybe you better let the dealer do it. In theory, it's
    easy. Since you don't mention what the sprocket is on, I'll assume the
    worst case. First, spend an hour or three figuring out how to remove the
    bodywork to get to the sprocket. Then' spend a little more time getting the
    guard or whatever off. Notice that you don't have a wrench to fit the large
    nut, and ChannelLoks aren't going to do it. Put the bike back together and
    go to the parts store for the tools.
    Get back home, take it apart, lean on your shiny new socket, and learn about
    the virutes of a liberal application of red loctite by some bored factory
    dweeb. Pick the bike up, since all you've done with a big wrench is to turn
    the entire drive train and move the entire bike forward off the kickstand.
    Place a piece of pipe through the read wheel to prevent futher excursions.
    Find 4 feet of pipe for a breaker bar extension, and apply maximal effort.
    Note the spokes bending.
    Scan the internet, and drop back to plan B. Remove more bodywork so you can
    get a sparkplug out. Cut down the wife's clothesline and stuff the
    cylinder. With an absolutely immobile bike, apply more torque to no effect.
    Scan the net some more. Borrow the pissed off wife's car, go to the hardware
    store and buy a propane torch. Come home, fire up the torch. Note that a
    considerable amount of gas dripped out when the bike fell off the stand and
    is now burning fiercely. Call the fire department. They get there too late
    to save the garage, but at least the house is only lightly singed.
    Find that the new bike you've bought with the insurance money comes with a
    brand new sprocket.
    Best case scenario: it'll take about 15 minutes including adjusting the
    chain.
    bowman, Feb 29, 2004
  5. SportBikes Canada
    Mark Olson Guest
    I'd be careful about making the front sprocket any smaller than a
    15T. Smaller diameter sprockets are harder on the sprockets and
    chain. You'd do better to make the rear two or three teeth larger.
    http://www.google.com/groups?selm=
    Mark Olson, Feb 29, 2004
