Changing Brake Hoses
Discussion in 'UK Motorcycles' started by Say it as you See it, Apr 14, 2007.
  1. Following on from my brake pad problems the brake lever is still a bit soft
    , having had advice for all methods of bleeding (and thats being mild),
    standard bleeding, calipers above the master cylinder, pressure bleed, using
    a cable tie to keep the lever in over the weekend, everything bar reverse
    bleeding, I'm now going for changing the hoses (apparently they can stretch
    and swell.)
    Once the new hoses are fitted is it going to be another case of all of the
    above including the frustration? Or is someone going to tell me an easier
    method please.
    Bleedin' brakes is causing me a F%£$&*g Nightmare.
  2. Say it as you See it
    Buy a fucking Mityvac. Grief over.
    Pip, Apr 14, 2007
  3. Say it as you See it
    ginge Guest
    All hail the Mityvac!
    ginge, Apr 14, 2007
  4. Say it as you See it
    Peter Jones Guest
    I use a big hypodermic syringe to pull the fluid through, absolute
    piece of piss with some home brew clear tubing from the bleed nipple to
    syringe end.
    Peter Jones, Apr 14, 2007
  5. Say it as you See it
    Tunku Guest
    Had the same on a neglected 305. New hoses sorted it. I reckoned they
    must have been ballooning under their outer covers. Went from trying to
    go round roundabouts at 80 with the front brake mashed to the throttle to
    throwing myself off the front just by looking at the brake lever in one
    day. :)
    Tunku, Apr 14, 2007
