Chain wear
Discussion in 'Motorcycle Technical Discussion' started by David Croxford, Oct 4, 2004.
  1. Can anybody give me details on how to check when a chain needs replacing? My
    1954 edition of "Motor Cycles and how to manage them" states that a quarter of
    an inch total end movement per foot is the threshold. However, I think a more up
    to date source is indicated. :) I know the sticker on the swingarm next to the
    adjusters to be wrong.
    The bike is a Honda CB500S with an RK 525<mumble> O-ring chain. I'll probably
    replace the chain very soon anyway due to the condition of the sprockets, but it
    would be nice to know.
  2. David,
    some but not total help.
    My contemporary Susuki's manual states a maximum distance across 21
    pins (ie., 20 links) of the chain. Regretably, the chain nomenclature
    is different than yours, but perhaps Honda can provide a similar
    number. Just FYI, my chain is RK50MFOZ1 and the maximum is 319.4mm or
    12 9/16". That's on a 2000 Suzuki GSX750F, for what it's worth.
    My guess is that if the sprockets are visibly worn, you're already
    toying with fire. In your spot, I would go straight to new chain and
    sprockets.
    D
    Douglas Moffitt, Oct 4, 2004
  3. When adjusting it every so often become a frequent pain.
    Or - when the transmission vibration and backlash becomes a frequent
    pain.
    Or both.
    Rule of thumb. Works for me.
    The Older Gentleman, Oct 4, 2004
  4. David Croxford
    the fly Guest
    If the sprocket tooth profiles are visibly worn, you should
    replace both sprockets and chain, immediately.
    The old rule of thumb is: grip the chain across one of the
    pins, at the rearmost edge of the rear sprocket. Pull that pin toward
    the rear, out away from the sprocket. If the chain comes off the
    sprocket enough to expose half the height of a tooth, it's time to
    replace the set.
    the fly, Oct 5, 2004
  5. David Croxford
    OH- Guest
    To increase the confusion even more, here is another rule of thumb:
    Try to pull the chain away from the rear sprocket at the 3-a-clock
    position (straight to the rear). If you can lift it enough to see half
    a tooth, it's time to get a new chain, a new front sprocket and most
    likely a rear sprocket as well.
    OH-, Oct 5, 2004
  6. David Croxford
    moragcliff Guest
    The Older Gentleman Opined:
    pain.
    What would cause a chain to behave this way prematurely? I thought I
    was taking good care of my chain, but it caused noticeable surging at
    10K miles.
    Usual maintenance: o-ring safe spray every 600 miles,
    inspection/adjustment every 3K miles
    Changing the chain and sprockets was an expensive and time-consuming
    ordeal. The new chain has a 20K mile warranty, and I'd love it to last
    that long.
    --Cliff
    GSF600S ('03) "Bounce"
    GL650 ('83) "Eunice"
    moragcliff, Oct 5, 2004
  7. It's a Honda 500 twin, right? Twins and singles always give chains a
    hard time, and remember that with its 180 degree crank throws the Honda
    has the same firing intervals as a vee twin.
    It's just that one (or two) big bangs per specified time interval is
    tougher on a chain than four smaller ones in the same time.
    Oh, and get the wheel alignment out and life will be reduced as well.
    Dy Ducati has a stout chain, but its power pulses (and near total lack
    of driveline shock absorbers) mean chains rarely last as long as 10,000
    miles. My Triumph, on the other hand, hasn't needed adjustment, never
    mind replacement, in nearly 10,000 miles.
    Changing a chain and sprockets shouldn't be too expensive or
    time-consuming on a Honda 500, anyway.
    And offering a 20k miles guarantee on a chain is a very brave move,
    IMHO.
    The Older Gentleman, Oct 6, 2004
  8. Unless moragcliff has a 500 he's not mentioned in his sig, I think you've got
    your posters mixed up, TOG. You're still right though.
    I'm now shopping around for the parts. Any recommendations w.r.t chain
    riveters?
    Thanks for the advice so far, everyone.
    David Croxford, Oct 6, 2004
  9. David Croxford
    OH- Guest
    I'll keep on being difficult. I realise that a riveted master link is "a
    good
    thing". But a spring clip one should do fine on 500 twin. Or ?
    OH-, Oct 6, 2004
  10. Yes, I've also just found out that most new DID chains come with a "unique"
    type of rivet, for which they claim one needs their special new riveter. If I
    was rash, that could have been a rather nasty surprise.
    David Croxford, Oct 7, 2004
  11. The first digit in the chain number indicates pitch in eighths of an
    inch. So a 425 chain would have a pitch of 4/8" (0.5").
    Wes
    Wesley W. Garland, Oct 9, 2004
