Chain tension adjustment
Discussion in 'Motorbike Technical Discussion' started by Puddin' Man, Mar 18, 2009.
  1. Are you now satisfied you've proved to all rmt readers that you don't
    know how to adjust chain tension?
    The Older Gentleman, Mar 20, 2009
  2. You're angling for another death threat, aren't you Neil? Is this
    a new troll or a morph? -- I've been away a few weeks. Torino was nice,
    the bus ride down into France from the Mont Blanc tunnel was scary -- I
    might not be able to do the last few km on a bike (a bit like the road
    Adny Woodwrad took us on back to Ystumtuen from Machynlleth -- I'm scared
    of heights so roads with minimal/no guardrails and >100 m vertical
    dropoffs worry me excessively!)
    Dr Ivan D. Reid, Mar 20, 2009
  3. Well, he is such a moron....
    I'm in a hotel in San Pedro de Atacama, north Chile, right now. Lovely
    place. Spent this morning wandering around th geysers in the Andes, at
    an altitude of over 14,000 feet.
  4. No, you don't. Hacksaw through it. Use a rivetable master link on the
    replacement chain.
  5. Puddin' Man
    Puddin' Man Guest
    Lordy Mercy, I thought it would be an old-style master-link chain. No such
    luck: gotta remove the swing arm, etc to free the chain.
    I did a closer inspection. The rear sprocket teeth look OK to me. There
    were some small kinks in the chain. I probably wasn't meticulous about
    putting enough lube on it every spring. Saw no rust, though.
    I just lubed it liberally and ran it about 1 mile. There's still some
    tiny kinks, and there's about 7/8" of play in the chain. I'm thinking
    it *might* work out about right after I put 20+ miles on it.
    An interesting question (?):
    Given a standard swing-arm design, what positive or negative load might
    result in a variance in the distance from the center of the driving
    sprocket to the center of the rear sprocket?
    P
    "Law Without Equity Is No Law At All. It Is A Form Of Jungle Rule."
    Puddin' Man, Mar 20, 2009
  6. Puddin' Man
    ? Guest
    It's not all that simple. The swingarm pivot is not in the center of a
    direct line between the two sprockets. And if you have a single shock
    rear suspension, it's
    probably connected to a linkkage that compresses the spring less in
    the initial movement and more as the swing arm moves toward the rear
    fender.
    ?, Mar 21, 2009
  7. Puddin' Man
    ? Guest
    This is the last time I'll let you nibble on my dick. You always bite.
    ?, Mar 21, 2009
  8. Puddin' Man
    frijoli Guest
    Okay I ahve been watching this and this ? guy is either a troll or he
    has no clue as to what he's talking about.
    I used to sell industrial chains for a living, and the factories that
    make them, make the chains for ALL motorcyles, both OEM and aftermarket.
    I've been there and trained by factory people about their chains. Some
    very high stress industrial chains are in fact the SAME chains we run on
    our bikes.
    OEMs by the best price chain that meets what their engineering teams say
    they need PERIOD. Aftermarket chains that claim to be better usually are.
    By a DID or Tsubaki chain made for your bike and you'll get the best
    chain for you're money, and possibly the same chain that came on your bike.
    OEM sprockets are fine for what they are engineered for, and most times
    for anything you make them do. If you race, by a race sprocket. Racing
    sprockets typically wear out faster than normal OEM sprockets because
    they are not as hard. They are not as hard because of the shocks they
    have to take, and therefore don't brake.
    Clay
    frijoli, Mar 21, 2009
  9. Puddin' Man
    ? Guest
    If Tsubaki makes RK chain. If you buy a chain with the SAME numbers on
    the link as your OEM chain, it IS the same chain.
    The main difference between RK premium chains found on new bikes and
    aftermarket RK chain is usually the O-ring design.
    Some kits have little donit-shaped O-rings that will wear out in 10K
    miles.
    OEM RK GSV chains have a flat washer-shaped O-ring with two raised
    ridges on either side.
    Those O-rings will last 20~25K miles...
    ?, Mar 21, 2009
  10. Bwaaahahahahahaha!
    You were trolling.
    Yeah.
    *Right*.
    The Older Gentleman, Mar 21, 2009
  11. The first alternative:
    No. He really is that stupid.
    The second:
    *Ding* with added helping of *dong* and a side salad accompaniment.
  12. Jesus. How stupid can you be?
  13. Puddin' Man
    ? Guest
    Not stupid enough to pick up your rattle again...
    ?, Mar 21, 2009
  14. No, they're not. Not the sideplates, anyway.
    You what? Whyever not? It takes maybe a couple of minutes to do.
  15. Puddin' Man
    Puddin' Man Guest
    Yeah, I shoulda said "*supposed* to remove the swing arm, etc" (per junk manual).
    But I got this picture in my head of po' me hacksawing and hacksawing and
    .... until my arm falls off. The chains are case-hardened? No ways easy
    to get at with a hacksaw, either.
    I, myself, thought of a cutting torch. I suppose I could de-grease enough
    of the chain with brake-parts-cleaner that it wouldn't burst into flame.
    Hopefully this is academic for now: I'm not yet convinced the old chain is
    truly shot.
    Maybe a very hi-grade metal-cutting blade in a reciprocating saw ...
    The local bike shop (midwest US) has DID master-link chains: $30 without
    O-rings, $130 with.
    P
    Puddin' Man, Mar 21, 2009
  16. Puddin' Man
    Puddin' Man Guest
    Thanks. Had I been fully thinking, most/all of these would've occurred to
    me.
    I'm thinking ... get new chain, loosen old chain, stack some bricks or
    a cinder block under it, big old screwdriver with tip ground sharp like chisel
    (to get side-plate started), large ball-peen and some regular chisels.
    Cheers,
    P
    Puddin' Man, Mar 22, 2009
  17. Puddin' Man
    red_bowfire Guest
    I've got the same bike, 62k miles. I went through chains every 15k miles
    or so, and each time I replaced the chain I replaced the rear sprocket.
    Never did the aluminum sprocket or 520 size chain, always stuck with OEM
    sizes. During some of my dry economic times, if I found a kink or two, I
    always tried to work them out with lube, but could never do it.
    As for lifting this bike, before I bought my Lockhart swing arm stand, I
    used to take the front fairing off, and used two small trailer jacks
    (small stands with a threaded rod that allowed me to adjust the height
    of the stand) under each arm of the engine frame. Then I'd stick a small
    floor jack under the header pipes (or engine pan if pipes were off),
    lift the floor jack, adjust the trailer jacks, lift the floor jack, etc.
    until I could get everything even and stable.
    I ended up getting a Motion Pro rivet kit to remove and install my own
    chains. Chaparral Motorsports ate up all the small, local dealerships,
    and I didn't want them touching my bike.
    My bike is still in good condition after all these years, however I've
    woefully neglected it as I've spent most of my time on my new Victory Vegas.
    red_bowfire, Mar 22, 2009
  18. Puddin' Man
    Who Me? Guest
    All the while leaving the badly worn front sprocket to tear up the new
    chain..........
    Have you since figured that out ??
    Who Me?, Mar 22, 2009
  19. Just a hacksaw. Really.
    The Older Gentleman, Mar 22, 2009
  20. Puddin' Man
    Schiffner Guest
    I haven't figured out when it became unfashionable to flip you
    sprockets over...
    Schiffner, Mar 23, 2009
