Chain Sprokets
Discussion in 'UK Motorcycles' started by Say it as you See it, Jun 12, 2007.
  1. I need to change my chain sprockets but the choice has overwhelmed me. I
    have a choice of sprockets from between 42 teeth and 48 teeth going up in
    increments of 1.
    Could someone please explain what the difference is (apart from teeth count)
    and what differences it will make to the handling/speed of the bike.
    Many thanks.
  2. Say it as you See it
    Boots Guest
    Unless you've got a reason to change then fit the same sprockets as
    are already fitted or what ever the manufacturer recommends.
    The ratio between the number of teeth on the front and the rear
    sprockets is what matters. So if you increase the size of the rear
    sprocket whilst leaving the front alone then the overall ratio will
    change. So that you would find the acceleration enhanced balanced by
    the speed at which you'd reach the redline being reduced in each gear.
    Decreasing the rear sprocket will have the opposite effect (obviously)
    and the front works in the opposite way to the rear. However, note
    because front sprockets are smaller the change will be more dramatic.
    Boots, Jun 12, 2007
  3. Say it as you See it
    Paul - xxx Guest
    The more teeth on the rear sprocket the lower the overall gearing would be
    .... so if you use a sprocket with more teeth than currently fitted you'll
    get faster [1] acceleration but slower top-end. If you use a sprocket with
    less teeth it's going to make the bike slower when accelerating but faster
    overall, assuming the power is there to counteract wind resistance etc. ;)
    Note, just one or two teeth difference *can* make a huge difference to
    'feel' and if you have the choice it's well worth experimenting with
    different sprockets to find what suits you, the bike and your riding
    environment best.
    [1] For varying values of 'faster'.
    Paul - xxx, Jun 12, 2007
  4. Say it as you See it
    Adrian Guest
    Say it as you See it () gurgled happily, sounding much like they
    were saying :
    Go and ride a bicycle fitted with derailleur gears. You'll quickly figure
    it out.
    Adrian, Jun 12, 2007
  5. Say it as you See it
    MikeH Guest
    A helpful suggestion which makes sense.
    What have you done with the real UKRM?
    MikeH, Jun 12, 2007
  6. You have to reach the redline in *every* gear? That's why the Divvy's
    dull then!
    Steve Fitzgerald, Jun 12, 2007
  7. Sir is apparently unaware of the mandatory requirements that are placed
    upon the rider of a motorcycle.
    Of course, there are some motorcycles where requirements are somewhat
    easier to achieve.
    steve auvache, Jun 12, 2007
  8. Say it as you See it
    Boots Guest
    Well at the very least you should try.
    Boots, Jun 12, 2007
  9. Say it as you See it
    Pete Fisher Guest
    Depends. A sprocket change which affected handling is hard to imagine.
    The Roadster has benefited greatly from a change from a 40 to 42 rear
    sprocket. Much more responsive but still not revving too hard. The bike
    is general considered 'overgeared' as standard though.
    | Pete Fisher at Home: |
    Pete Fisher, Jun 12, 2007
  10. Say it as you See it
    Pete Fisher Guest
    I see your point, as a specifically road holding problem rather than
    general handling.
    Not to mention the impromptu wheelies.
    Some hillclimbers regularly change gearing by really quite high
    percentages to suit different hills (a higher spread than a road racer
    would usually need to contemplate I suspect).
    Having said that, if gearing way down for a very short hill or to get
    exactly the right intermediate ratio to hold through a particularly
    tricky section, a second gear start strategy might come into play (not
    many cassette gearboxes MX bikes in use as yet).
  11. Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    PAH...
    <thinks>
    TENNAH!
    Wounded Uncle Nigel - Podium Placed Ducati Race Engineer as featured in
    Performance Bikes and Fast Bikes
    Honda GL1000K2 (Falling apart) Kawasaki ZN1300 Voyager "Oh, Oh, It's so big"
    Wicked Uncle Nigel, Jun 12, 2007
  12. Say it as you See it
    Yer a hard bastard, WUN.
    More power to yer elbow.
    Pip, Jun 13, 2007
