Chain or shaft
Discussion in 'Classic Motorbikes' started by taz, Nov 26, 2004.
  1. taz
    Rob Guest
    I think it was on Fri, 26 Nov 2004 01:00:13 GMT that "taz"
    Belt?
    Rob
    Broseley, Shropshire
    1991 Yamaha XV 535 Virago
    1997 Rover 623GSi
    Rob, Nov 27, 2004
  2. taz
    Klaatu Guest
    Braces ?
    Klaatu, Nov 27, 2004
  3. taz
    Salad Dodger Guest
    This one?
    http://www.salad.dodger.dsl.pipex.com/wing.jpg
    It's a special - enclosed chain running in an oil bath inside the old
    shaft housing.
    Honest.
    | ___ Salad Dodger
    _/_____\_ GLXR1500SEVRRSP/CBR1100XXX/KH500A8/TS250C
    |_\_____/_| .....73063...../..17090.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
    Salad Dodger, Nov 27, 2004
  4. hehe.
    actually, the expression of concentration on the pilot's face leads me to
    believe it.
    and besides, I can;t see any physical explanation for "shafties don't
    wheelie", provided it's a powerful enough motor, of course.
    Austin Shackles, Nov 27, 2004
  5. Austin Shackles wrote
    It was explained over in ukrm 4 or 5 years ago and debated by people who
    can do sums and hold strong opinions in the face of overwhelming
    evidence to the contrary and everything. I was as surprised as anyone
    to see that, on paper at least, this appeared right.
    However, a year or so later, it turns out that in a sense they was all
    wrong. Well those of them who had said that shafties can wheelie and
    that they hadn't taken into account the direction of rotation of the
    final drive shaft and it was probably an either or thing between
    wheelieing and stoppieing or, in most cases, neither.
    This didn't go down to well, as a google will tell you, and some really
    nasty things were said by both sides about the other. None of which had
    any real relevance to the point but made very good evening entertainment
    for sad bastards like me with no life and no hope of one, so I
    encouraged them.
    Anyway, it turns out that the rotational directional thing may have a
    grain of truth in it. The proof being apparently that a shaftie *may*
    be able to do one but simply cannot do both. Although there was a
    school of thought that maintained that as most of the sums included a
    variable which was to do with rubber tarmac friction forces, albeit
    offset by the turning forces applied to the shaft, any hint of the back
    wheel leaving the road spoilt the maths summat horrid and the rest of us
    were all muppets and should be removed from the gene pool for thinking
    anything else. You don't tend to hear much from them though as they are
    the sort of person that nobody likes.
    Oddly, the one thing everybody does seem to agree on is the lack of
    skills shown by most photoshop users these days.
    steve auvache, Nov 27, 2004
  6. hehe.
    however; the fact remains that regardless of which way the shaft rotates and
    whether or not it tries to compress or extend the rear suspension when under
    power, the ultimate source for the torque accelerating the machine is the
    weight of the machine itself. If there's enough grip, and enough power in
    the engine, then it'll lift the front of the machine off the deck.
    Suspension compression due to the transmission may help this, on machines
    where this happens, mostly those with chain drive.
    's like anti-dive forks. You can] design a suspension system which has
    anti-dive, either using hydraulics or geometry, but at the end of the day if
    the brakes are sufficiently powerful and the tyre grip sufficiently high,
    then it'll stoppie as well.
  7. taz
    Austin Shackles says...
    I defy you to stoppie a ZZR1100 with very sticky tyres on. I tried and
    nearly put myself through the back screen of a Mondeo. Too long, too
    heavy and too low a CoG. The front will lock just after the rear comes
    up.
    Lozzo, Nov 27, 2004
  8. Austin Shackles wrote
    Look, I am the wrong person to explain all this, what you need is a
    mathematician. Like I said it has all been done on ukrm a long time in
    the past and a google will explain the sums and everything. Including
    father Xmas
    I'll had anti dive forks. I didn't do no deliberate stoppies though.
    My view is that if the back, or front for that matter, wheel ever comes
    off the ground then something unplanned has happened[1] and I don't
    enjoy that.
    [1] Although thinking back to when I used to commute on my 305 that was
    how I approached every roundabout and set of red lights. It was
    controllable easy fun to have the back just skipping, I couldn't resist
    it.
  9. yebbut, that's the point, innit. heavy bike and not enough grip (it may be
    that no tyre exists with enough grip). But in theory, with a grippy enough
    tyre and road surface... you might of course not live to tell the tale, but
    since when has that been a facet of the argument?
    not likely to find out about the wheelie potential, with my bike. It'd not
    wheelie even if it were chain-driven; not enough power.
  10. taz
    Preston Kemp Guest
    There's no such thing as not enough power to wheelie. There is such a
    thing as not enough technique though ;-)
    Preston Kemp, Nov 27, 2004
  11. very likely. the bike's fairly heavy though, and so's the rider, and it
    only had 40 bhp when new.
  12. taz
    Preston Kemp says...
    Very true. I've only found a couple of bikes that wouldn't lift the
    front in some small way.
    Lozzo, Nov 28, 2004
  13. yesyes, I know, you can wheelie a C50 if you plant both feet on the floor
    first...
    actually, ISTR getting the front wheel of my first bike, a Honda H100,
    slightly airborne by a combination of too much revs and too
    rapid-application of the clutch. But I hesitate to describe it as a
    wheelie, as such. More like an
    "argh-oh-****-phew-jesus-I-must-look-a-right-tit".
    Austin Shackles, Nov 28, 2004
  14. taz
    Ben Blaney Guest
    Yes.
    Ben Blaney, Nov 28, 2004
  15. taz
    Mike Fleming Guest
    Or 85 quid apiece as I pay for the Tigger:
    http://www.busters-accessories.co.uk/products.asp?id=54
    Lubing by Scottoiler with a touring reservoir takes that chore to
    refilling the reservoir every 8k miles or so. Chain gets adjusted
    about every 5k miles.
    BMW shafts need dismantling at about 15k intervals to lubricate the
    drive shaft splines. The rear drive transfer box needs its oil changed
    at about 10k intervals. High maintenance items, these shaft drives...
    Mike Fleming, Nov 28, 2004
  16. taz
    Mike Fleming Guest
    If I was to get the bike engineer doen the road to do it, probably an
    hour of labour per change. Worst case two hours = £60, so £240 total.
    It must be terrible when a chain completely catches you unawares by
    wearing out.
    It is, of course, a pefect excuse for owning more than one bike.
    Realistically, it's the sort of job that, if you actually want a shop
    to do it and not do it yourself, you would ride in and ride out a
    couple of hours later with it done.
    True. I shall have to find some way of recycling them in future.
    I have no great objection to shafts. I do suspect that those who
    evangelise about them as the panacea for all ills don't actually know
    anything about the subject though.
  17. taz
    C50s require use of the foot clutch while moving slowly in first. It can
    be done and quite often was when I used to borrow my ex-girlfriends one.
    Lozzo, Nov 28, 2004
  18. taz
    Lozzo, Nov 28, 2004
  19. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember Austin Shackles
    First proper wheelie I did was when I was giving a workmate a lift out
    of the works carpark on the back of a ShiteOldVespa. Needing more
    throttle to take off, I gunned it and performed an impressive (to me, at
    the time) wheelie out of the works gates, scattering assorted
    engineering types left right and centre.
    Much shouting and cursing was heard.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Nov 28, 2004
  20. taz
    Andy Clews Guest
    Thus spake Lozzo unto the assembled multitudes:
    I had a C70 back in the early 80s and it was easy to wheelie that with
    pretty much the same technique.
    I also wheelied my first two-wheeler, a (ssshhh don't tell anyone) Lambretta
    SX200, on several frightening occasions. I think it was enjoying its
    new-found liberty, having been owned previously by a woman who weighed about
    25 stone. 'kin 'ell, I'm amazed I survived riding that thing with zero
    training or experience. Talk about a baptism of fire...
    Andy Clews, Nov 28, 2004
