Chain Lubrication
Discussion in 'UK Motorcycles' started by Vegetable Grower, May 31, 2006.
  1. Does anyone have any thoughts about a good chain lubricant/oil? 4000
    miles between services seems a bit too long when I'm doing 100 miles/day
    commute. M&P seem to have a wide selection but I haven't a clue where to
    start...
    <Dons flameproof suit>
  2. Vegetable Grower wrote
    Chain oil.
    Fit a touring Scotoiler.
    steve auvache, May 31, 2006
  3. Vegetable Grower
    Dan L Guest
    Hmm, I recently used Castrol Chain Wax and found it to be very easy to use,
    and so far, the (I believe) OEM chain on my Zephyr looks like it still has a
    lot of life left in it.
    Others here have reported that Chain Wax is the sputum of satan, and
    wouldn't touch it with yours, let alone a barge pole. The can I used
    purported to be "new formula", so perhaps it was crap, but is now okay.
    Anyway, my 2d's worth, IIWY I'd fit a Scottoiler.
    Dan L (Oldbloke)
    Space in shed where NSR125 used to be
    BOTAFOT #140 (KotL 2005/6), X-FOT#000, DIAABTCOD #26, BOMB#18 (slow), OMF#11
    Dan L, May 31, 2006
  4. Vegetable Grower
    You weren't seriously considering 4k miles without lubing the chain,
    were you? You'd be looking at twice a week on a warm chain (when you
    get home rather than before you set off) with a decent quality aerosol
    lube. Silkolene or PJ-1 spring to mind, but I'd stay away from chain
    wax by preference.
    For the ultimate in fit-and-forget, a Scottoiler with a touring
    reservoir is the only answer.
    http://www.scottoiler.com/
    Pip, May 31, 2006
  5. Vegetable Grower
    Snotoiler.
    Timo Geusch, May 31, 2006
  6. I now use Putoline O-ring chain lube. I've tried many others including
    chain wax (which I hate), PJ-1 etc and now believe that the Putoline is
    among the best. It *does* fling off a bit but that's because it's oil but
    it does the job very well. I normally clean the chain with a WD-40 soaked
    rag to get all the shit off then give a dose of Putoline. I normally lube,
    drive a few miles then clean the back wheel with WD-40. After the initial
    fling-off period it seems to stick fine but unlike other lubes, the chain
    retains that nice wet lubed look.
    Um, or get a Scottoiler.
    Freddy Kruger, May 31, 2006
  7. Vegetable Grower
    I've used it and it seems OK, though nowadays I tend to use oil or a
    shaft drive.
    I still use chain wax for winterising alloy wheels and generally
    spraying onto unpainted metal like spindle nuts, adjusters and so on.
    Bloody pads keep rubbing it off the discs, mind.
    Pip Luscher, May 31, 2006
  8. Pip Luscher wrote
    Fucker innit? I beat that by not bothering with brakes.
  9. Vegetable Grower
    Magpie1892 Guest
    I concur with Putoline.
    I use the same stuff and only lube when the rings look shiney!
    They should look dull if lubed ok. Works out at about 500 miles i re
    lube depending on weather etc.
    Ken
    Magpie1892, Jun 3, 2006
