chain life for Yamaha xv250
Discussion in 'Australian Motorcycles' started by Colin King, Oct 15, 2003.
  1. Colin King
    Colin King Guest
    Hi all, maybe this is one of those "how long is a piece of string"
    questions, but I'm just wondering, cos I don't think mine has lasted as long
    as it should ...
    I got my first bike in June last year, a 92 Yamaha XV250. The guy had to
    replace the back tyre for the rego, and that's still going strong, but I had
    the chain and sprocket replaced in February, and now it's pretty well due to
    be done again. I got a heavy duty standard chain, figuring that a 250
    probably wouldn't really need an O-ring chain, but maybe I should have just
    spent the extra $?
    I've done a lot of k's of course ... I average nearly 400 a week, and it's
    just clocked up 20,000 ks since I bought it. So I don't know if that's about
    average life expectancy or not.
  2. In aus.motorcycles on Wed, 15 Oct 2003 23:19:49 +1000
    For a non-orring chain? yup. IN fact very good for one not running in
    grease.
    Zebee
    Zebee Johnstone, Oct 15, 2003
  3. Colin King
    Andy Oudyn Guest
    How do you know when the chain needs replacing?
    or should you just replace the chain with the sprockets whel they start
    wearing baddly?
    Thanks
    Andy Oudyn, Oct 16, 2003
  4. Colin King
    FuTAnT Guest
    They'll begin to stretch (ok, so they don't stretch, they wear out more
    rapidly. The metal on the rollers and the metal on the pins etc start to
    wear giving that 'stretching' idea) and need adjustment more often. When
    you have to start adjusting the thing every few weeks it's pretty much
    shagged. If you pull the chain backwards off the rear sprocket in a
    direction parallel to the ground and the chain comes away from the sprocket
    any more than about 3 or 4 mm it's pretty shagged too! Alot of the time
    it's a case of how far are you prepared to push it!
    Cam
    '00 ZX6R
    FuTAnT, Oct 16, 2003
  5. Colin King
    FuTAnT Guest
    20,000 ks is pretty sweet out of a standard chain. I wouldn't be
    complaining anyway. They're cheap and you can lube them up quite easily. If
    you are interested in extending the chain life think of putting something
    on like a Scottoiler etc, they do wonders. Still yet to get around to
    putting on one myself, but they're exxy to buy in the first place. Ah well,
    atleast you can take them off and take it with you when you change bikes.
    Cam
    '00 ZX6R
  6. Colin King
    vinyl Guest
    Aren't sprockets supposed to look long in the tooth?
    vinyl, Oct 16, 2003
  7. Colin King
    RM Guest
    Someone let Colin King at loose on an
    internet connection and the result was:
    GAW people these days!!...you adjust the chain till it wont any more, then
    remove some links and go again...and again...then the front sprocket will
    start rounding off, eventually the teeth on the front sprocket will
    dissappear and it will start slipping, THEN you fit new chain and sprockets
    If you get 20K out of a standard chain (which is quite good) you should get
    50 000 using this method.
    I would recommend ignoring this advice, it is for amusement purposes only,
    failure to maintain chain drive correctly may result in loss of control of
    the motorbicycle.
    RM, Oct 16, 2003
  8. It depends, of course, on the chain too... I'm used to getting 40
    or 50 thousand km out of a chain on the Spada, I _usually_ use a
    good quality o-ring chain (RK brand usually, 'cause thats what
    the local place stocks). A while back, they were out of RK
    chains, but told me these "ISIS" brand ones were "almost as
    good", and only half the price... So I tried one. 6000km later I
    had to replace the chain again, and it took the sprokets out with
    it :-(
    I've now got over 30,000km on its replacement RK chain, and I've
    only just tweaked the adjustment for the first time...
    It seems to me that $130 odd for "the best 428 o-ring chain
    you've got" is a *lot* better value than a $70 crap chain...
    big (oh, and it helps if you keep it clean and keep it lubed...)
    Iain Chalmers, Oct 17, 2003
