Chain Breaker/Rivetter
Discussion in 'Motorbike Technical Discussion' started by Dave Hall, Jun 28, 2004.
  1. Dave Hall
    Dave Hall Guest
    Hi,
    I have just bought the above mentioned tool, but as it came without
    instructions, I have no idea how to use it. Can anyone help?
  2. Dave Hall
    Mark Olson Guest
    Is it the Motion Pro tool? I just bought one, it came with a sheet
    of instructions.
    http://www.motionpro.com/Docs/chaintools.html
    Their website has some instructions online:
    http://www.motionpro.com/images/02-pdf/08-0058-instructions.pdf
    I used mine to push out a pin in the old chain (grind off the rivet
    head first, though) and to press on the side plates and swage out the
    pins on the new master link. It works as well as can be expected.
    I would advise lubricating the threads before use, it takes quite a
    bit of force when pressing the side plate and swaging the pins.
    If you have more questions, post them here, someone will probably be
    able to help.
    Mark Olson, Jun 28, 2004
