chain adjustment suzuki GSF 650
Discussion in 'UK Motorcycles' started by kitey, Apr 27, 2008.
  1. kitey
    kitey Guest
    Hello
    I am wanting to adjust my chain on a 2006 GSF650. The manual says
    remove cotter pin,and then loosen bolt before adjusting tension.
    My axle does not have what I thought a cotter pin is, and I am bit
    stumped.
    is there a chance it has something else that is stoppig me from
    lossening the axel bolt.
    Thanks in advance
    kitey, Apr 27, 2008
  2. Comprehension?
    The Older Gentleman, Apr 27, 2008
  3. kitey
    Speedgazebo Guest
    The phrase "cotter pin" refers to the Split pin in the axle nut. I
    suspect you, like me, identify a cotter pin as something that holds a
    pedal crank on a bicycle.
    Odd though, my 1200 Bandit had nyloc type nuts.
    Speedgazebo, Apr 27, 2008
  4. kitey
    I think a 3' breaker bar would probably help him more.
    Andy Bonwick, Apr 27, 2008
  5. Either there's a broken off bit of split pin [cotter pin] going through the
    castellated nut and the axle, or you are lacking the strength necessary to
    move the nut.
    I are a large chap, not at all lacking when it comes to wielding a socket
    wrench, but undoing the rear axle nut on the Viagra nearly made me shit my
    liver out.
    Mungo \Two Sheds\ Toadfoot, Apr 27, 2008
  6. kitey
    kitey Guest
    Thanks for the pointer about the nyloc type nuts Speedgazebo. Is that
    basicaly a normal looking nut, with something against the thread.
    looks like i could knock it out with a terminal driver or soemthing.
    Very hard to describe it.
    Could you describe it, and tell me how you would remove it
    kitey, Apr 27, 2008
  7. kitey
    astraweb Guest
    Acording to my manual the cotter pin is fitted to Canadian models only,
    you are just lacking oomph, get an extention bar for your socket, when
    I first adjusted the chain on mine I spent ages checking for a left handed
    thread,
    but no, it's just fucking tight.
    astraweb, Apr 27, 2008
  8. kitey
    kitey Guest
    Thanks for the candian advice (I got the manual off the web).I wil try
    and get an extension bar and give it a go
    kitey, Apr 27, 2008
  9. kitey
    Pete Fisher Guest
    In communiqué
    A nyloc nut has a ring of nylon visible between the nut and the thread
    of the wheel spindle. If you have a hole in the side of the nut with
    something in it, then Mungo may have the right of it. Though you would
    normally expect to see at least the head of the split pin remaining.
    A wheel spindle and nut that have been taken roughly with a split pin
    while not lined up correctly, then left to corrode nicely can be
    challenging to separate.
    | Pete Fisher at Home: |
    Pete Fisher, Apr 27, 2008
  10. kitey
    davethedave Guest
    Harsh but fair
    davethedave, Apr 28, 2008
