CG125s
Discussion in 'Classic Motorbikes' started by Austin Shackles, Jun 15, 2006.
  1. when did the new model come out with 12V electrics?
  2. someone I know has been offered a free B plate one, but it seems to be a 6V
    one. Last of the old type, I'd guess, then. and presumably a pushrod motor
    as well, not that there's anything wrong with that of course...
  3. *AHEM*
    The Older Gentleman, Jun 16, 2006
  4. Austin Shackles
    So, obviously not one of the bevel-drive DOHC versions, then?
    platypus, Jun 16, 2006
  5. Austin Shackles
    The Older Gentleman said...
    My girlfriend's mother has just bought a brand new CG125[1]. It's really
    quite nice, with new stylish bodywork, disc brake and electric start.
    They even supply them with decent Pirelli tyres nowadays. All she needs
    to do now is learn to ride it without crashing into walls in Wroxham[2].
    [1] MSOHP
    [2] I need to replace a fork stanchion and fork seal for her, as the
    hard chrome is scuffed and had wrecked the seal. Not bad going for a 12
    mile old bike.
    Lozzo, Jun 16, 2006
  6. <innocent>
    what?
    </innocent>
    besides, the SOBoxer is pushrod...
    Austin Shackles, Jun 16, 2006
  7. Austin Shackles
    I used to dream about a belt or chain driven 4 valve head OHC
    conversions for SOBeemers. The guy who built the V12 kawasaki could have
    done it easily. Shame BMW came up with such an unappealing version,
    SOB's vibrate but in a pleasant lumpy kind of way and you can cruise at
    60 or 90 smoothly. The oilheads and harsh vibey tingly POS in comparison
    IMHO.
    Hog, Jun 16, 2006
  8. Hack a lump off a Cosworth/Alfa/ head as a starting point and Bob's yer
    transvestite relative. I suppose a SOHC would be better for ground
    clearance, though.
    Some of the air-cooled Porsche heads might fit...
    On a related note, the Holy Grail of A-series tuning was a DOHC ally
    head - mucho money for fresh metal in its day; now it can be done
    relatively easily with K1100 head.
    Grimly Curmudgeon, Jun 16, 2006
  9. Austin Shackles
    MattG Guest
    No idea, but they're still shit.
    MattG, Jun 16, 2006
  10. Austin Shackles
    kenney Guest
    The prewar racing DOHC bikes but the camshafts below the valves
    and used rockers to reduce width. However it is perfectly
    possible to use a push rod four valve head. Rudge did after all
    and there was a four valve head conversion available for the
    Triumph twins. IIRC the first Cosworth speedway engines used a
    push rod head as well. A lot depends on what the main limit on
    revs is. The Vincent valve gear was good for 7 or 8 thousand RPM
    the standard big end got unhappy over about 5.5.
    Ken Young
    kenney, Jun 17, 2006
  11. And the Honda CX V-twin series, of course.....
    The Older Gentleman, Jun 17, 2006
  12. Austin Shackles
    I always found that impressive.
    Pip Luscher, Jun 18, 2006
  13. Austin Shackles
    Yes but they were very short pushrods and the original CX top ends were
    not exactly trouble free.
    Other than the material choices for the followers etc and an excessively
    tight crankshaft run for the cam chain which destroyed them asap the CX
    was an outstandingly good engine.
    If they had applied good surface treatment technology and used a gear
    driven cam it would have been a wonderful bike, particularly in the 650
    Euro prolink guise. I liked the comstar wheels (if you kept corrosion at
    bay around the rivets), they were lighter than the cast lead alloy
    wheels of the day and tougher/less maintenance than spoked wheels.
    Hog, Jun 19, 2006
Similar Threads
Loading...
