Hi everyone A little advice on cg125 problems I've been having for the last couple of weeks. Symptons: -lots of kicking required to start -trying to open throttle when first started (by even the smallest amount) causes it die -will not start with choke (at all) -will not usually start with throttle open -once warm (i.e. been running on tick-over for a while), will rev and is rideable, however in wet weather it will unexpectedly cut out (e.g. while nipping along at 50mph the engine will just die - engine seems quite warm but it will restart) -I'm not sure if this is related, but once when it cut out, it backfired (with quite a bang). I thought it had blown a seal or gasket somewhere but it seemed okay. It's got a good spark, so I don't think it is an electrical fault unless the timing's out or something. Has got plenty of oil etc. thanks, Pete
