CG125 speedo
Discussion in 'UK Motorcycles' started by Peter Windridge, Jan 4, 2005.
  1. Dear all
    went out on the cg125 (does sign) after she'd been in shed for nearly 2
    weeks only to get half a mile or so and realise the speedo wasn't
    working. It was definitely working on the last outing (bike test :))
    but now nothing. Throughout the ride, the speedo would occasionally
    flick up but otherwise apparently nothing. Taking off the cable and
    spinning the wheel reveals that the cable is not being turned (as
    opposed to a the unit in the dash being faulty).
    Taking off the wheel and turning the worm wheel and 'cog'[1] that turns
    it reveals everything is fine that point onward.
    I've done the obvious like greased drive worm wheel in wheel, oiled the
    cable and checked the alignment of the hub notches to those on the
    'cog'[1] but has made no difference.
    To my untrained eye it seems possible that the notches on the 'cog'[1]
    which are driven by those in the hub are worn, as spinning the wheel in
    the opposite direction results in the cable turning ok.
    If anyone has any tips or help to offer I'd be very grateful. Also, is
    it a legal requirement to have a working speedo? I know what 30mph,
    40mph are roughly on my bike (accurately enough to no get gatso'ed, I
    think) but I can't remember it ever being mentioned at MOT.
    thanks, Peter
    [1] I dont know the proper name for this.
  2. Peter Windridge
    TOG Guest
    The cable's probably broken right at the bottom, and when you turn the
    wheel round the other way the broken ends just mate up enough. Have you
    actually removed the cable inner to check?
    Yes, indeed.
    TOG, Jan 4, 2005
  3. Peter Windridge
    Petel Guest
    message
    <snip>
    Sounds obvious but did you actually pull the inner cable out to check if
    it`s snapped half way down?
    Don`t grease/oil the top couple of inches of a speedo cable where it enters
    the clock, the grease can work it`s way into the speedo and damage it.
    Petel .
    02 M2 Buell.
    C90-ZZR.
    Piaggio/Gilera 125 Red Dwarf Sprinter
    http://homepage.ntlworld.com/peteh1/website/index.html
    Petel, Jan 4, 2005
  4. *sheepish look* d'oh on both counts. I'll take a look.
    thanks, Peter
  5. I haven't removed it and will take a look. When I turn the cog that
    drives the worm wheel (in the right direction) the cable turns though..
    I suppose its possible though that it works without the hub in with a
    broken cable.
    Thanks for your help Tog,
    Peter
  6. Colonel Tupperware, Jan 4, 2005
  7. Peter Windridge
    Mo Childs Guest
    You can use a bicycle speedometer. Electronic digital type. Available
    Do bicycle speedos go up to 35mph then?
    Mo Childs, Jan 4, 2005
  8. Peter Windridge
    They'll go up to 99mph and have handy trip, average and maximum functions.
    sweller, Jan 4, 2005
  9. Colonel Tupperware, Jan 4, 2005
  10. Peter Windridge
    sweller says...
    My BC700 goes to 200mph apparently, not that it's ever been close to
    that on a CB250RS.
    Lozzo, Jan 4, 2005
  11. Peter Windridge
    Mark Olson Guest
    The Sigma BC600 and BC800 go up to 186mph / 300 km/hr.
    Mark Olson, Jan 4, 2005
