CBR600f4i battery problems?
Discussion in 'Australian Motorcycles' started by Kiva, Apr 3, 2006.
  1. Kiva
    Kiva Guest
    Hi,
    Went overseas for 5 months and bike stood idle at home. When I came back I tried to start it and obviously it was dead due to
    uncharged battery. I went to jump start it from the car and the bike started fine, HOWEVER, as soon as I removed the jumper leads,
    the bike cuts out and switches off. I tried leaving the jumper cables on to charge the battery for 15 mins or so but same problem.
    I do have a power commander installed if this would affect anything..
    Is this normal ? Is it just a dead battery ?
    TIA
    Kiva, Apr 3, 2006
  2. Kiva
    Theo Bekkers Guest
    Looks like you have a dead battery.
    Umm, you can't charge a battery with jumper leads. You stand a good chance
    of blowing it up though.
    Theo
    Theo Bekkers, Apr 3, 2006
  3. Kiva
    Rod Bacon Guest
    Is threre any fluid in it?
    Sounds knackered to me...
    Rod Bacon, Apr 3, 2006
  4. Kiva
    G-S Guest
    It's probably rooted. You could try a small battery charger (one of
    those cheapies
    from K-Mart of supercheap would do), if it charges it isn't rooted if it
    doesn't charge then it is rooted.
    G-S
    G-S, Apr 3, 2006
  5. Kiva
    Theo Bekkers Guest
    How will he know? :)
    Theo
  6. Kiva
    CrazyCam Guest
    <snip>
    There you go...the problem in one.
    Motorbikes that aren't used go off... sometimes bang sometimes whisper.
    You _should_ have found someone to look after and bike-sit for you
    before you buggered off.
    Yes. Probably.
    regards,
    CrazyCam
    CrazyCam, Apr 3, 2006
  7. Kiva
    J5 Guest
    buggered battery
    prob got a dead cell
    J5, Apr 3, 2006
  8. Kiva
    alx Guest
    lead acid batteries dont like being left flat.
    Get a new battery then get a battery tender (charger trickle charger
    SPECIFICALLY for motorycle size batteries...)..around $80 from Dick Smith
    for example.
    alx, Apr 3, 2006
  9. Kiva
    G-S Guest
    Oh.... pfffftttt :)
    G-S
    G-S, Apr 3, 2006
  10. Kiva
    GB Guest
    Nah mate, I just ate an ice cream.
    GB, oops, wrong joke.
    GB, Apr 3, 2006
  11. Kiva
    Theo Bekkers Guest
    But, but, but, my bike has a car-sized battery. Do I still have to get a
    motorcycle battery charger? And what would the difference be?
    Theo
    Theo Bekkers, Apr 4, 2006
  12. Kiva
    Theo Bekkers Guest
    That's why I'm careful to use only the factory supplied battery leads which
    squeeze the volts down to their proper motorcycle size.
    Theo
  13. Kiva
    G-S Guest
    If you have a car sized battery get a car sized charger (4 to 8 amp range).
    If you have a large bike sized battery get a small car charger or a bike
    charger (2 to 4 amp range).
    If you have a little piddy bike battery (like lots of trail bikes) then
    definitly get a bike charger or trickle charger (1 to 2 amp range).
    Putting a large charger on a small battery can exceed the maximum charge
    rate. Sure it'll drop (eventually) but even the minimum can be too high.
    I wouldn't use a 4 amp car charger on the XT250 trail bike battery (kick
    only) as an example, but my 1 amp plane trickle charger is perfect.
    The internal control circuits on most cheap battery chargers don't have
    a great amount of 'control'.
    G-S
    G-S, Apr 4, 2006
  14. Kiva
    G-S Guest
    Don't be silly!
    Volts are a standard size... it's amps that come in different versions!!
    G-S
    G-S, Apr 4, 2006
  15. Kiva
    HandleBarz Guest
    HandleBarz, Apr 5, 2006
  16. Kiva
    alx Guest
    thank gawd someone's provided a respectable answer to the Big Volts Small
    Volts bulshit
    alx, Apr 8, 2006
