CBR600 - voltage out of alternator?
Discussion in 'UK Motorcycles' started by Dundonald, Oct 4, 2005.
  1. Dundonald
    Dundonald Guest
    Evening chaps. My battery isn't charging so I've done a few checks,
    all things currently point to the reg/rec unit. But before I go ahead
    and buy a new reg / rec I want to make sure the AC voltage I'm reading
    out of the alternator is good. I'm reading 50-51 AC volts at around
    5000 revs. At idle, 1000 revs, it's about 11-14 AC volts.
    Sound about right?
  2. Dundonald
    Dundonald Guest
    Forgot to say, I checked all three sequences and each output the same
    voltage (50-51 at 5K revs).
  3. regulator should be kicking out something around th14 volt mark any lower
    and it wont charge your battery much higher and it will fry your battery
    alternator voltage will vary thats why its regulated
    Steve Robinson, Oct 4, 2005
  4. Dundonald
    The OP is quoting the no-load AC voltage, which could well be up at
    that level. Sounds fine to me.
    Pip Luscher, Oct 4, 2005
  5. Dundonald
    It's in the right ballpark for a no-load voltage IWHT, especially if
    all three phases read the same.
    Have you made sure that the alternator resistance is nice and low and
    that it's not shorted to earth too?
  6. Dundonald
    Dundonald Guest
    That's a good PDF that, a copy saved, thanks.
    Aye I checked the resistance of the phases from the alternator and
    compared all readings against figures in the haynes manual, all looked
    good.
    Thanks for your help.
  7. Dundonald
    Dundonald Guest
    Good to hear, thanks Pip.
    Aye all readings were good and compared well with figures in the haynes
    manual.
    Looks like reg / rect is the problem then.
