CBR1000 - clean carbs, lousy idle problem
Discussion in 'Motorbike Technical Discussion' started by tj, Sep 16, 2003.
  1. tj
    tj Guest
    Bike is a 1990 with 8,000 original miles, and is extremely clean and well
    kept for its age (the point is that I know that I'm not chasing gremlins
    such as a rusty tank, corroded connectors, etc).
    Bike starts okay... idles rough. When I twist the throttle slowly, it will
    climb up to 2000 rpm roughly but successfully. It runs fine over 2000 rpm.
    When I blip the throttle quickly, it coughs terribly, and seems like its
    misfiring terribly... and if I don't let up on the throttle, it dies.
    I've removed and cleaned the carbs three times. They look almost new.
    Every passage got elbow grease in conjunction with carb cleaner and a blast
    of compressed air. I took off the jets, the floats, the diaphrams,
    everything. There wasn't a speck of gunk in there anywhere, and everything
    moves smoothly. The pilot screws are also A-OK.
    I checked the fuel filter in the tank - its like new.
    Plugs all look normal - none fouled, none wet with oil or gas, they look
    ideal.
    I took it to two shops: they didn't bother looking at the bike - but both
    insisted that all I need to do is clean the carbs.
    The damn carbs are clean.
    Help?!
    tj, Sep 16, 2003
  2. tj
    rhino Guest
    On the off chance that Do you have clean carbs you might have an intake
    valve not seating completely causing your problems If the bike has sat for a
    while or seen limited use it may have rusted or gummed up valve stems or
    face/seat.
    Hook up a timing light to each cyl one at a time and look down each carb
    throat at idle to see if there is and fuel being spit back.
    But I wouldn't rule out dirty carbs
    rhino, Sep 17, 2003
  3. tj
    Geribaldy Guest
    I fully agree.When I balanced my brothers' CBR1000 carbs I could stop the engine with a tiny
    adjustment on the balancing screws.
    Geribaldy, Sep 17, 2003
