CBR 600 Cam chains
Discussion in 'UK Motorcycles' started by Ian, Dec 24, 2003.
  1. Ian
    Ian Guest
    As a haggling point at what mileage should it be renewed and what would a
    proper mender charge for doing it ?
    TIA
    Ian
    Ian, Dec 24, 2003
  2. If the tensioner has never nadgered, it should last for at least 50,000
    miles, and probably much longer.
    A dealer would probably charge about ukp150 for a soft link replacement.
    If you're looking at one and it's rattling, it's the tensioner, not the
    camchain, that's fucked, and that's only a 50 quid job.
    The Older Gentleman, Dec 24, 2003
  3. Ian
    Phil Wattis Guest
    CBR600 CCT's are notoriously bad. If it has failed at an unreasonably
    low milage then you may be able to get your dealer to replace it FOC,
    even if the warrantee is out. I have heard of them going at only 2000
    miles, and then the replacement lasts a few thousand miles more!
    IIRC the part is about 50ukp, and a dealer will quote 2 hours labour.
    Having looked in the Haynes manual for the FX model and later I can
    well believe it.
    Phil.
    Phil Wattis, Dec 24, 2003
  4. Ian (Gth@AAA£$.net) wrote:
    : As a haggling point at what mileage should it be renewed and what would a
    : proper mender charge for doing it ?
    I'm still on the original cam-chain and tensioner at 68,000 miles. As
    others have posted it's usually the tensioner that packs up. You can
    replace it with a manual one;
    http://www.debben.co.uk/acatalog/Debben_2003_Engine_parts_19.html
    Blair.
    '97 CBR600
    B.G. Finlay IT Services, Dec 24, 2003
  5. He's asking about the camchain, not the *tensioner*.....
  6. Ian
    Phil Wattis Guest
    He's asking about the camchain, not the *tensioner*.....[/QUOTE]
    Sorry, asleep for Xmas already.
    Phil.
  7. Ian
    Chris H Guest
    message
    I've had two out of five CBR6's start to rattle after 10,000 miles and
    if you don't get the tensioner replaced immediately, then the camchain
    may well need to be replaced too. I've always had the work done within
    warranty, but even if your one is out of warranty a decent dealer should
    argue your case with Honda.
    You've not stated which model year the bike is and IIRC, early ones had
    the camchain in the middle of the block and then later ones it moved to
    one side, so that, presumably, you wouldn't need to split the engine to
    change it.
    Fuel pumps tend to go at 20-25K. Check the suspension, because on early
    ones I was told that the rear shock isn't rebuildable.
    Chris H, Dec 24, 2003
  8. Ian
    Ian Guest
    Thanks Gents, I'll be looking at mid-nineties models in the new year. Most
    of the ones advertised are about 30K miles or less. I just wanted an extra
    haggling point.
    Thanks again
    Ian
    Ian, Dec 24, 2003
