Friend got it cheap after it sat for five years, 31,000 kilometres. Local technical school dis-assembled and cleaned carbs, swapped forks from parts bike, changed oil & filter, adjusted valves, put in new battery, front pads, new plugs and possibly wires (can't be sure - they look new). not sure about the coils, swapped chain, carbs synch'ed. The day after he drove it home it wouldn't start so I tried to check charging and discovered that rotor was shorted (great pointer from Mike Nixon at [URL="http://www.motorcycleproject.com"]www.motorcycleproject.com[/URL]). Swapped rotor and stator, now charges well enough, I think. However it still took up to twenty long bursts to get it started (just as before). Choke (old-fashioned air choke) seems to close nearly all the way, plugs after about a 50 km ride to his place were fairly clean on the electrode but black on the nose. Found manual on internet and noticed it says to start the fuel pilot screws from 1 1/2 to 1 3/4 turns out, then continue to turn out. Noticed that screws were set at about 2 1/4 turns. Smelled a little gassy on start attempts but for no good reason other than I have sometimes had success by leaning the pilots, I turned them in to 1 3/4 and it seemed to start quicker after waiting for a couple of hours. (The thing with this bike is that once you get it started, even if you run it for only five minutes and then wait three hours, it will start right away without the choke, so I the next morning I went over and it started after about six tries.) Then I turned the pilots down to 1 1/2 turns and 'phoned him the next morning. He had already been trying to start it for some minutes, but had forgotten to turn the petcock on. Once he did it started on the second attempt. I told him if all is good it should start after several seconds or less on the first attempt, so he asked me to turn the pilots down to 1 1/4 turns. Tomorrow morning we'll know if that made any difference. I'm always afraid to lean out air-cooled bikes too much. We plan to find an oil cooler but the expected rider for the next couple of months is a retired guy who misses his Goldwing that he got rid of some years ago. I guess to be more careful about it, I really should measure the float height even though these floats are the non-adjustable kind as well as double-check the float valve seats. The older gent is quite anxious to take it home and get on it and get back into the riding habit. I'm wondering should I worry that I may have leaned the pilots too much? After I set them to 1 1/2 friend took around neighbourhood (I wouldn't do it because it is un-licensed at the moment) and told me it pulled well in all gears, even in fifth going up hill at city speeds). I don't mind taking an hour or two to pull the carbs and disassemble the bottoms. Thought of putting a can of Motul fuel system cleaner and seeing what happens after a tank or two but from what I'm seeing there could just as easily be a slow-speed air blockage. (Oh, also, at 1 1/2 turns, bike idles around 2,000 with choke on, you can take the choke off after less than a minute and it settles down to about 1,200 rpm. Whereas when pilots were at 2 1/4 turns, after you took the choke off and gave it throttle to 3,000, most of the time, it would not return to idle, which is another reason why I had the feeling it was too rich, ie., float too high in one or more of the jets.) Thanks for any comments, p
