I am pulling my hair out on this one. I have an old CB750 which has (sadly) sat in a shed in my backyard for about 8 years. I sold a few motorcycles this spring, basically all the working ones, hoping to pick up a Ducati that an acquaintance was going to sell. Sale never happened, so here I am stuck with no bike. Ahhhh, the old CB in the shed. So I spent some time this summer getting it to a roadworthy state, in fact I've got the motor running very well after a top-end tear-down. Here's the problem: I cannot get the front brake cylinder to work. I ordered a rebuild kit off eBay which looked identical to the parts I took out. I assmebled as per the schematic shown on the Bike Bandit website: [URL]http://www.bikebandit.com/houseofmotorcycles/1973-honda-motorcycle-cb750k3/o/m9234[/URL] The kit was all the parts inside the polygon noted as #13. For the two parts of #2, the seal on the right slides over the end of the piston and seats on a ridge at the left side of the thin part of the piston. I also changed out the brake lines (replaced with braided steel) and the caliper piston seal. When I put it all back together and added some brake fluid, it didn't leak, nor would it bleed. I put a piece of tubing onto the bleed nipple on the caliper and dropped the end into a jar of brake fluid so I could see bubbles, or lack thereof. The first pull on the lever pushed out a big bubble, then I closed the bleed nipple and released the handle. When I opened up the bleed nipple it sucked fluid up into the tube, there was a vacuum in the system... so it appears no fluid was getting past the master cylinder seals to replace the air that got pushed out. I removed the brake line from the caliper and did a little test. I put my finger tightly over the outlet and speezed the lever. Yup. Pressure. I then released the pressure (keeping the lever pulled in) and put my finger back and released the lever. Vacuum. Waited a few seconds thinking it'd pull some fluid or air or something past the seals but no, it was still a vacuum after 10 seconds or so. I purchased another master cylinder off that auction site thinking maybe mine was hosed, but symptoms are identical. I tried using a syringe to make sure I had fluid filling the cylinder, i.e. no air in the chamber. Anybody have any ideas? Am I missing something fundamental? Did I maybe get the wrong rebuild kit? Dave
